1930s Era Champ Car - new project
Discussion in 'The Hokey Ass Message Board' started by THE FRENCHTOWN FLYER, Nov 20, 2007.
  1. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I made these strips to hold on the body panels. Way back when, the body panels were usually held in place with angle flanges riveted to the edges of the panels. Now it would be soooo much easier to attach them with quarter-turn Dzus buttons but to stay close to original I just embossed rivet heads on the flanges and will spot weld them on to the body.
    mgtstumpy and tb33anda3rd like this.
  2. 64 DODGE 440
    64 DODGE 440
    from so cal
    Maybe it's just my retired aircraft mechanic background, but I think I would have just gone ahead and riveted them. :p
  3. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I'm looking for jobs to do with my new spot welder.
  4. Smokey2
    Smokey2
    Frenchtown, It's nice to find Threads like yours, it gives us not so talented
    hambers drive to finish meager tasks.
    I really get tired of seeing posts like
    "How do I get the window cranks off
    my chevy ?" I know we all gotta learn
    but come on ! Great fabs on here, and THANKS to You and Others that take the
    time to Post and take photos.
    Great Build !:cool:
    quote: "I don't do Body work"
    Ian Berky
    HaHa
    prefect20 likes this.
  5. terryble
    terryble
    from canada
    What kind of motor is that?
  6. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Thanks Smokey2.
    terryble, its a Ford 300.
  7. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I made some additional body mounts for the rear section. A couple of these were a bit tricky as they had compound bends in the flanges, i.e., they bend in two directions:
    mgtstumpy and kiwijeff like this.
  8. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    The driver's cockpit gets trimmed and wire-edged, using 1/4" soft steel rod. Because this piece was too big to get into my bead roller easily I did most of the wiring with hand tools.
    mgtstumpy, tb33anda3rd and kiwijeff like this.
  9. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I placed all the semi-finished panels on the chassis to mount the body to the frame using the flanges, like they used to.
  10. gnichols
    gnichols
    from Tampa, FL
    Looking good! Gary
  11. I haven't looked at this thread in a while... I'm glad I came back to it. Inspiring work, it looks incredible.
  12. 41 Dave
    41 Dave
    Hi there TFTF . . . Like the way you are shaping the body mounting strips. Also like all the vintage details that you will add to the motor and ignition system. Hoping to add something like that to the mill in my Modified. Got to get it made more vintage era. Maybe they will let me sneek in on the local hill climb race . . . .
    Dave
  13. 41 Dave
    41 Dave
    Hi TFTF ! thought my previous post had failed. It is there so I am modding this one with some other thoughts. I wanted to know if you would have detail pix of all the little items that will post date your 300 I-6 ? I wanted to see if I could get some ideas to post date the mill in my modified. I do belief it will somewhat disguise my newer motor.
    Dave
  14. CoolHand
    CoolHand
    Alliance Vendor
    Beautiful build sir.
    You are one hell of a metal man.
    Obviously a not too shabby engineer as well.
    Can't wait to see this thing finished.
  15. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    41 Dave, All the retro details I have done so far I have posted on this thread: the DOHC valve cover, the 'crab' distributor, the intake and headers. I plan to add orange plug wires with Rajo clips to a set of dummy plugs sunk down between the cam towers and a few brass oilers and maybe a tapered cooling manifold on the 'head'. The real plug wires will be routed under the headers and hidden by a loom cover.
    Thanks for all the kind words guys.
  16. jim henderson
    jim henderson
    I really like this style of car. Nice work !
  17. Pete1
    Pete1
    from Wa.
    Yes, EXCEPT, you need to make the bend in the front two pipes a 4 pie bend rather than a single pie. That doesn't match the rest of the quality. And grind off the welds. It will have that mandrel bend look then.
  18. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Pete1, The photo may look like I pie-cut straight pipe to make the bends for the first two pipes, but actually there is a piece of tight radius tubing in there to make the transition "smooth". I did this so all the pipes coming out of the hood all have a uniform straight look to them when the hood was closed. I will polish all the pipes to give them an even color before I "heat age" a lean mixtured blueish patina into them. But I don't want to grind the welds smooth, rather leave them more functional and less show-car like. I hope the final result will take the abuse I intend to give it without having to worry about premature weld joint failure. We'll see.
  19. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Ron Covell, aka "Professor Hammer", did an article in Street Rodder (January, 2014, pg 132) answering a question I had about how to make a head rest for the rear body section on this car.
    I will take Ron's advice andbuild a buck and make two sides welded together. When I built the rear body buck I made a headrest pattern so I have a starting point done.
  20. allenrussell
    allenrussell
    any chance there are new/up-dated pics of this project since photos in Street Rodder Jan 2014? Would you share building techniques?
  21. allenrussell
    allenrussell
    sorry, I posted previous message, before looking at pics in thread. I have had this style build in mind, for lots of years now. Your project has re-motivated me. I don't begin to have your talent, but will persevere somehow. Thanks for sharing
  22. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    allenrussel,
    There is somebody making repop sprint / champ car bodies now. Joshua Shaw, a HAMB member built a tribute car from one that was featured in Street Rodder a couple years back. A 'glass body like that will put you way ahead of the game.
    I also will let you in on another dirty little secret: When I decided to built this one, I hedged my bets by building the chassis so it would accept a '27T roadster body in case my home built champ car body didn't turn out. That is why I chose to not pinch in the ends of the frame rails, like so many of the cars of that era had. But I've committed to finishing the champ car body as most of the hard decisions are solved.
    Come to think of it, wouldn't it be cool if I did make a '27T body to interchange? Or maybe a belly tanker since I'm center steered?
    I will continue to update pics as progress warrants. Thanks.
  23. xpletiv
    xpletiv
    from chiburbs
    Subscribed!!
    Don't keep me waitin'.;)
  24. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    OK xpletiv. Thanks for subscribing.
    Today I showed a pic of my car to one of the ARCA execs and he invited me down to one of the tracks they sanction (Toledo Speedway) to make some hot laps. Oh boy! I gotta get krackin'.
  25. Molin61
    Molin61
    from Karlshamn
    Nice projekt, fun too see other builds. You probably right, some holes could be good.
  26. 64 DODGE 440
    64 DODGE 440
    from so cal
    Question Frenchtown. I've been following the build but somewhere missed a bit. What front axle and spindles are you using on the build? I have a similar looking piece that I acquired for a future build and was wondering of it's parentage so I could find parts as needed.
  27. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    The fromt axle is from a 1953 Ford F100 (F1?) pickup truck. I modified it by narrowing it 6 inches in the middle. Then I cut off the original spring pads from the parallel leaf suspension. Then I drilled the I-beam. Then I welded on the batwings to hold the Model A spring perches and sway bar. Then I cut the steering arms off and lengthened them so the shortened tierod will clear the new batwings at full steering lock. A little sanding with an angle grinder removed the forging flash marks. The last thing I want to do is use the original spring pad locating bolt holes to attach lever arm shocks. I welded nuts inside the front frame crossmember to anchor the shocks which I will fabricate. The spindles and brakes are stock Ford. I may fill the brake backing plates with lightening holes.
  28. hey there mate, im an engineering student currently trying to build my own inline six sprint racer midget, any chance you could share with me your plans as well as any advice you might have on the build up of this project?
  29. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Hi. I did not do a set of blueprints for this car - merely some sketches and then built the body bucks. The frame is 2 x 4 rails spaced 23" apart (outside dim.) and the wheelbase is 110". It is longer than most champ cars because I am tall and will be using a 3-speed auto trans. Most midgets are in the 80 - 90 inch wheelbase.
    Hope this helps. Good luck with your project.
    6re6
  30. King ford
    King ford
    from 08302
    Hey flier any progress on the champ car?.....really cool build,....im'e kind of kickin around the same idea for a v8-60 and speed goodies I have, MAYBE in a streetable version ...kind of watching your build as a guide!
