Projects 1930 Tudor Sedan, My first build
Discussion in 'Traditional Hot Rods' started by LuckyFord, Dec 8, 2015.
  1. LuckyFord
    LuckyFord
    Here is what I started with.
    20130912_194035.jpg 20130912_194053.jpg 20130912_194117.jpg 20130912_194153.jpg
  2. LuckyFord
    LuckyFord
    wow sorry. no idea why the pics are repeating.
  3. LuckyFord
    LuckyFord
    20130927_174651.jpg 20130927_174638.jpg 20130927_174704.jpg before I started with the chassis
    kiwijeff likes this.
  4. LuckyFord
    LuckyFord
    Narrowed the chassis 4" from stock at the firewall to fit the A. Put factory x member back inside the frame. fully boxed the rails in 10 gauge plate. installed parallel 4 link and pan hard in rear. sleeved the frame for the hairpin mounts. Got her all square and straight, found a previous repair and some rust in the rear sections, got it all fixed now. 20130902_165934.jpg 20130902_165954.jpg 20130902_170013.jpg 20130902_170039.jpg 20130902_170108.jpg 20130902_170125.jpg
  5. Right on. I like where this is going. What kind of power are you planning on using?
    The Wizzard
  6. King ford
    King ford
    from 08302
    Looks like 1 horsepower!
  7. trollst
    trollst
    Times two....looks like it'll have some serious horsepower.
  8. I thought that was a Big guard Dog.
    The Wizzard
    Stogy likes this.
  9. LuckyFord
    LuckyFord
    That's funny. I've said before when someone looked at the pics it had one horse power ha ha . Got two shortly after that.
    Stogy likes this.
  10. LuckyFord
    LuckyFord
    Went round and round on power plant. Finally my budget helped decide small block. Its a 69 corvette small block, setup like a sleeper, cast head stroker ready for a cheater shot;). I am further along and will post more pics, just wasn't sure if anyone would be interested. I kind of went off in my own little world with the whole 60's street race theme, some guys don't like it.
  11. LuckyFord
    LuckyFord
    Oh and it bites like a dam guard dog!
    Stogy likes this.
  12. LuckyFord
    LuckyFord
    Here is a mock up with a junk 350 and the Muncie manual tranny. Got some extra bracing in the x member. Added tranny and motor mounts. Body test fit on chassis perfect. The coupe chassis pinched in was a great fit for the sedan. Cant take credit for the idea, the guy I bought the rails from said it was a common builders trick back in the 50's. I see why now! 20140126_201925.jpg 20140126_201953.jpg 20140127_163505.jpg 20140127_172952.jpg 20140127_173014.jpg
    AHotRod and kiwijeff like this.
  13. Nice job, sedans rock! Keep us updated
  14. LuckyFord
    LuckyFord
    Made some rails to tie the rear of the body back into the floor. Matched the curve in the frame. Put inner fender panels in.
    20140214_160341.jpg 20140214_204312.jpg 20140214_204355.jpg 20140215_140714.jpg 20140215_160859.jpg 20140217_195107.jpg 20140217_195150.jpg 20140217_195200.jpg
    AHotRod likes this.
  15. I'm keen to see how this turns out.
    Love builds in natures workshop.
  16. LuckyFord
    LuckyFord
    Ya I fell in love with the car and didn't even have a shop yet. Funny addition, I work in the air conditioning business, so I was only able to do this at night and when the weather was horrible. Most people thought I was crazy, I just called it committed. Some people have no clue how many horrible hours are spent boxing a chassis. Because of not having a good floor, I spent more time building the mess of tube and beams holding everything in place for welding. Everything was measured and checked 50 times in between welding and moving braces around. At one point I counted 27 braces off my frame rails, looked like I was building a giant tube body, just to hold all the curves perfect. I think it came out pretty good for my first one, nice and square all around.
  17. panheadguy
    panheadguy
    from S.E. WI
    Looks like you are doing a great job with limited resources. Reminds me of my first build in the 60's.......The old man wouldn't let me use his garage. Pretty selfish of him but then I was sort of a messy pig too.
  18. I was building everything under an old tree in the dirt back in the '60s except when I used the ag shop down at the high school. LOL
    @LuckyFord the build looks pretty good man. So is it going to stay sedan delivery or are you repairing the back and putting windows back in it?
  19. LuckyFord
    LuckyFord
    Thanks. The blank offs in the windows were barely tacked in, so I pulled them out to just look at it for awhile. Turned out the openings themselves are in great condition so I'm going to leave them open. I am 6'4" and with the seat reclined to a good line of sight out the windshield, I may need to see out the sides for changing lanes. With the back window, I was thinking about making it the exact same size as the sides and at same height. I don't really care for the real skinny back window, and if I match the chop it will be skinny.
    Also, it has a ribbed corvair roof section tacked on top. That was ok for the delivery style, but not liking it now. It has no proper bracing and will have to come off either way, just not sure how I want to put it back. Maybe frame out a removable section to fill in the factory opening, set up with a rubber gasket and convertible top latches on the inside? Then it could be full roof or open depending on weather. Not sure yet.
  20. Well luckily nothing was done permanent to yours before you got it. makes it easier to change to suit you.
    I am in the process of undoing some ill thought out stuff on my project and they made it to last for at least another century. LOL
  21. LuckyFord
    LuckyFord
    Thanks. I can only say now that I really appreciate having my shop. I got by without it, but man what a difference having a good work space makes.
  22. LuckyFord
    LuckyFord
    Here is when she moved to the new shop. She collected some dust and cobwebs for the summer, but I got the shop done and ready to start going again. Collected a bunch of parts over the summer too.
    20151101_155238.jpg 20151101_155250.jpg 20151101_155309.jpg 20151101_155355.jpg 20151101_163148.jpg 20151101_171556.jpg
  23. You better watch that parts collecting, it will cause you to have a completed car then what will you do with your spare time. LOL
  24. Now we got two horse power, but you need to feed em horses, they're only half grown. :D
    One of my customers breed miniature horses for years.
    Once you crank that ol Chevy engine up, thatll scare em up a few sizes. ;)
  25. mike bowling
    mike bowling
    If you're tall, you've got to take all the room you can get from an "A".
    Nice project ( and the security horse is cool)
  26. LuckyFord
    LuckyFord
    Well hopefully drive the hell out of this one rounding up parts for the next;)
  27. LuckyFord
    LuckyFord
    Hey they don't know their little, they have never seen big horses lol.
    I did fire my new motor off a couple weeks ago, took a few hours to find the dogs afterwards.
    There is nothing like the sound of a v-8 with open collectors to get re-motivated to build!
  28. LuckyFord
    LuckyFord
    Nice ride Mike. You are far back far in there.
  29. LuckyFord
    LuckyFord
    Here is my new motor, tranny rebuilt, new flywheel, new clutch. Valve covers are temporary, just wanted to hear it run 20151107_190614_001.jpg 20151108_180717.jpg 20151108_180730_resized.jpg 20151108_180754.jpg 20151109_171832.jpg 20151109_183350.jpg 20151109_183404.jpg
    AHotRod likes this.
  30. LuckyFord
    LuckyFord
    Did a mock up with the 32 chopped radiator and 34 grill. I think its going to fit pretty good. Might have to build some inner structure into the grill to mount it better. Radiator hits the factory mounts perfect. Got my eye on a nice aluminum grill insert that would fit this grill.
    20151112_171922.jpg 20151125_202610.jpg 20151125_202641.jpg 20151125_202703.jpg
    AHotRod likes this.
