Solid freshly sand blasted 1930 Ford RPU body. Solid doors, subrails, tank, and dash rail. The rear sub rail needs replacement as well as the lower rear cab and the usual lower front cowl sections. Replacement parts for these sections come with the body. Also included is a new wood floor and installed new door latches. Doors are solid as a rock and have some dents but the dents aren't bad. The solid fuel tank came from a running model A coupe. All the door hinges and "A" piller hinges are in excellent shape as well as the front sub rails and extentions. The floor pan under the seat will need replacing, it looked good before the sand blasting, but is quite swiss cheesy now. Asking $3,500 OBO.
