Up for sale is a 1930 Ford Model A Roadster and here are the specs... 1930 Henry Ford Roadster Body (original) 1949 8BA pulled from a running 49 Shoebox Edelbrock aluminum heads Offenhauser 2x2 aluminum intake 2 8BA 2 barrel carbs (rebuilt) 1935 Ford 3 speed top loader trans (rebuilt) BLC Headlights 1932 Ford Truck Grill (original ) 1932 Ford frame (American stamping rails) 50" wide, 4" drop commercial axle Split wishbones with '39 Ford spindles Pete and Jakes front shocks, So Cal speed shop rears 1935 Ford truck steering box and column 1940 Ford Wheel (original) Front and rear springs are mono style with adjustable blocks to adjust height 1946-48 rear end set-up with So-Cal Speed Shop ladder bars 1939 Ford juice brakes 1939 Wide five artillery wheels w/ hubcaps 1939 Pedal assembly Stewart Warner gauge panel New aluminum radiator New master cylinder New wheel cylinders New seal beamed headlight bulbs New 9 gallon spun aluminum gas tank The Windshield is the wrong size for the stanchions so the stanchions will need to be chopped to fit. Roadster is titled and registered asking 24,000 or best offer... Thank you.
