This truck has been completely taken apart, and all ORIGINAL Ford sheet metal media blasted and powder coated in red oxide primer. New BearClaw door latches have been installed. The chassis is professionally built and each component powdercoated. The motor (350) and trans (700R) were removed from a running 1989 Corvette and professionally rebuilt (zero miles !). The rear end is a custom made, brand new Winters Quick Change. The exhaust system is new and beautiful. The custom aluminum fuel tank is complete with sender and pump, nicely mounted under truck bed.....and the truck bed is stunning! No rust, and the ORIGINAL 1930 wood, stripped and coated. This truck has zero bondo, it has its imperfections and is ready to finish to the level you want. All it needs is a steering column, wireing harness, driver side window, and fuel lines and you'll be driving in no time! There are boxes of parts included but not pictured. Pink slip in hand, registered 1930 P/U non-op Jeff 909-856-3934
Could be your last chance, might not be available after this weekend.....2 people very interested.....call for details....a chance to get a BRAND NEW rolling chassis, complete drivetrain, and beautiful body doesn’t come around at this price often! 909-856-3934
