1930 Model A Gasser (Sold)
Discussion in 'Cars For Sale' started by JohnnyCASHcadillac, May 11, 2019.
  1. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    City: Alta Loma
    State: California
    Price: 31,000
    City: Alta Loma
    State: California
    Price:30,000
    A little interest but not too much. Price is negotiable.
    This car has a build thread here on the H.A.M.B. It was built by Chucky and recently painted. The following is info written by Chucky on the thread.
    Car runs and drives amazing. Only selling to get something bigger for my family.
    Front suspension consists of : Stock axle (now drilled), new stock spring/bushings, new round-back spindles from Speedway with new kingpins/bushings. A disc brake kit, also from Speedway has been installed. Bones were obviously split and converted with ford tie-rod ends.
    Dagels "Super X" crossmember kit along with their boxing plates and brake master mount / pedal kit.
    Level 2 - 700R4 straight from Bowtie Overdrives
    Weiand tunnel ram, Eddy 500 carbs,
    383 balanced rotating assembly. Scat cast crank, .040" forged pistons, 6" long H-beam rods, thick flex plate and "400" balancer. The block came from ATK out of Texas, all machined and ready to assemble. It's a factory "roller" block, but it also has the provisions for a mechanical fuel pump. The factory "4 bolt main" bolts were swapped out to Milodon bolts.
    'Howards' hydraulic roller cam was installed along with a 'Cloyes' billet steel timing set, specifically made for a factory roller block. Aluminum cover and the 7quart pan - proceed to paint.
    The rear main seal is Fel-pro's flouro-elastomer. The oil pump is a Melling high volume. Every fastener is aftermarket, as is nearly every part of the entire assembly. The only stock items are the block (modified), the water pump (modified), the valve covers (GM authorized re-pops), and the distributor (modified with a Crane XRI electronic ignition). I guess the lifters (new GM factory hydraulic rollers) and the fuel pump push rod are about it.
    Steering is all new Vega box / Speedway column.
    Profiler performance aluminum heads. Spec's are: 195cc intake runners, angled spark plugs, 72cc combustion chamber, 2.05 x1.60 valves. I went with the 72 chambers because it set the compression ratio at 10:5.1.
    Heads bolted down with ARP bolts and Fel-pro head gaskets. Griffin aluminum radiator.
    'Action Machine' made the drive shaft. 1350 series non-greasable u-joints (stronger than greasable) mated to 24 inches of 3" diameter steel tube.
    Front wheels = Circle Racing 15" x 4.5" (standard backspace - 2") polished kidney bean
    Rear wheels = American Rebel 15" x 10" (standard backspace - 4.25") polished sprint
    Fresh paint. Ford Lime Gold. This car has Zero rust. Straight body. All glass intact and roll up and down.
    This car is meant for the street but has track ability.
  2. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  3. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    Besty34 likes this.
  4. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  5. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  6. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    fords-n-fatboys likes this.
  7. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  8. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  9. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  10. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    catdad49, Rick28, Thor1 and 1 other person like this.
  11. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  12. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  13. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  14. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  15. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  16. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  17. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  18. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  19. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    -Brent- likes this.
  20. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  21. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  22. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  23. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  24. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  25. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  26. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  27. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  28. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
  29. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
    catdad49, Thor1 and car doctor like this.
  30. JohnnyCASHcadillac
    JohnnyCASHcadillac
    from SO CAL-
