1930 Model A Coupe
Discussion in 'Cars For Sale' started by Mattbee, Nov 27, 2017.
  1. Mattbee
    Mattbee
    City: Canton
    State: Michigan
    Price: 22,500
    1930 Model A full fendered "Hot Rod"
    Original California Car. This was built to be a driver. Just hop in a go. The car was painted in the mid 1960's. The paint has been pretty muched untouched since. This model a does not have any rust or patch panels. This car starts right up and goes. A lot of time and efford was put into this car to make it a true reliable early hot rod. I have driven this car across the state and would not hesitate to do it again. Work done to the car includes:
    • Converted to early Ford hydraulic brakes with all new lines, and 1966 Chevelle Master Cylinder
    • Converted to 12V with rebuilt starter and generator
    • Rebuilt Stock engine with a aftermarket counterbalanced crankshaft, Weiand Hi Compression Head
    • New distributor with petronix ignition
    • Stock 3 speed trans
    • Thomas 2x2 intake with dual Stromberg 97's
    • Reds Dual Outlet Header with full 2" dual exhaust and Smitthy mufflers
    • New Champion aluminum Radiator (dyed black)
    • 1932 Ford Grille Shell
    • Dropped headlight bar with new 1933 Ford Commercial headlights with halogen bulbs (hi/low beams and turn signals)
    • 1950 Ford Steering box for better steering
    • 1940 Ford Steering Wheel
    • Seat moved back 4" for additional leg room and comfort
    • New Firestone big and little tires (7.50 and 5.50s) mounted to powder coated black 1936 Ford wheels
    • 4" Dropped 1934 Ford front axle with new Posie Spring
    • New "tube" style shocks all around
    • All new "clean" wiring and plumbing
    • New suspension components (tie rod ends, king pins, etc..)
    Price: $22,500
    Contact Matt at 734-612-7233
    -Brent-, lothiandon1940 and GZ like this.
