Projects 1930 Ford Truck Sheetmetal Work !
Discussion in 'The Hokey Ass Message Board' started by Flop, Jan 2, 2014.
  1. Flop
    Flop
    there is some bondo abuse in the doors
    no body line on the back of the cab :eek:
    a little rough around the edges
    found out why the body line was gone
    door top brazed on
    garnish moulding also brazed on
    every screw had to be drilled out or had to have a nut welded to it
    looks like a mouse and some spiders found a home here!
  2. Flop
    Flop
    this one has me confused...
    getting closer!
    [​IMG] :eek:
    some weirdo cement in the pillar?
    rot
    made the top of the pillar to fix up what was going on
    remade evrything at the top the bottom where there was rot and where the tank sits
  3. Flop
    Flop
    doors are rotten on top and repaired with brass
    first time putting a skin on up top !
    drivers side took a good hit .
    we may be looking for another door or a top soon . but the bottom will need a full skin as well
    well shes a little rough
    things escalated quickly
    why dont they make pickup truck subrails ? tudor stuff isnt even close !!
    luckily i had some old pickup subrails in stock . they have to be spliced in and the tudor new subrail had to be narrowed on the outer edge . nowhere close to being right out of the box
  4. deadendcruiser
    deadendcruiser
    Oh man. Another Flop model A build. I can't wait. Always top notch work. I think you are on to something with the truck subrails. Start fabbing them up and making some cash.:D
  5. willymakeit
    willymakeit
    Subscribing. I like nice metal work.
  6. Flop
    Flop
    thanks dead end ! :D:D
    thanks willy
    only 2 things i had to do get this crossmember to stock specs ..a little trim and weld on a new edge
    and bracing under the bolt holes
    weld through primer on both sides
    turns into these
    B pillar to subrail .16 gauge sheetmetal
    lets build a truck !
  7. grim1930
    grim1930
    from Norfolk UK
    I found when I did my rear crossmember the rear part on the original was curved but the repro was straight, so I made a new one rather than use the repro, do you know if yours was straight or curved ?
  8. Flop
    Flop
    grim . the repop now matches perfectly to a nice original i have .
  9. grim1930
    grim1930
    from Norfolk UK
    I guess they must have made different ones then as my original was solid at the back but rusted out further forward and had a curve to the back edge, my cab came form an aa truck but I thought they were all the same, maybe made at a different plant ?, the truck came from California but could have been made anywhere, would have been a whole lot easier if I had known some of them were straight.
  10. 3wLarry
    3wLarry
    from Owasso, Ok
    cool beans
    kidcampbell71 likes this.
  11. Nice metal work! Thanks for posting. Looking forward to this one.
  12. Flop
    Flop
    interesting grim . this is my 3rd truck and all were straight .
    ha thanks larry
    thanks tin bender !
    uhhhohh !
    important bracket in making these trucks solid . rivets to the rear crossmember from the b pillar and also the triangle bracket . fixed the bottom up .it was rotted out .
    b pillar rot
    need to hit in here ith the spot blaster
    bracketry all coming together
    not to bad for a bunch or repop/mismatched stock parts !
  13. 392modela
    392modela
    Subscribed
    posted with a box of crayons on the outhouse wall
  14. aonemarine
    aonemarine
    from Delaware
    subscribed!! How about knocking 3" out of the top and making it an extended cab??
  15. gordspeed
    gordspeed
    from Oregon
    Just saw your thread tonight! Ran across really nice sub rails yesterday.... scrolled down and saw you conquered your issue! I was going to point you in the direction of rails for sale but you are doing a nice job without! Keep It Up! Lookin GOOD! :)
  16. grim1930
    grim1930
    from Norfolk UK
    That cab is starting to look good already, Great work.
  17. ChefMike
    ChefMike
    very nice work! Nice to see it in the hands of someone that knows what there doing !
  18. carbuilder
    carbuilder
    Flop great work always enjoy your threads.
  19. The37Kid
    The37Kid
    Always good to see what is going on in your shop! Happy New Year! Bob
  20. Very careful and thorough reconstruction. Hope the winter doesn't slow you down.
  21. Great work,,but we expect nothing less from your shop!:) HRP
  22. Flop
    Flop
    thanks for looking out gordspeed!!
    chef and mike thanks !!
    you too Bob see ya at hershey !!
    winter slowed me some this week with my arm i can tell ya that !
    thanks hrp!!
    well drivers side is solid now time to wrap the thing in sheetmetal !
  23. Flop
    Flop
    cowl patch made in shop and tigged in !
  24. v8juice
    v8juice
    wow excellent work
  25. Flop
    Flop
    thanks v8
    well getting this door all apart
    even the ppatch panel was starting to rot out . nust have been a very old braze job / patch
    making a new skin . bead roller , english wheel, shrinker stretcher
  26. Hurley50
    Hurley50
    from NC
    Great work.... another one saved.
  27. Flop
    Flop
    thanks Matt !
    well cab corners that fit take some doing !
  28. brady1929
    brady1929
  29. Flop
    Flop
    thanks brady !
    shes a little rough around the edges
    and then this weird image came out after running the file over the damage
    shes in
    28-31
    The "weird image" looks a bit like the Devil or a Roswell alien giving us the finger -- but then again, it also resembles a classic Rorschach test, so I'm not sure what that says about me...
    In any case, excellent metal work as always, Tom!
