1930 Ford Model A sedan sitting on 32 rails. Rails are JW rod garage that they boxed, super bell 4” I beam, posie front spring, split wishbones with new ‘39 Lincoln brakes. Rear is a Pete and jakes style ladder bar with posie quarter elliptical springs. C channel type X brace crossmember. Rearend is out of a 85 t-type Buick with 3:42 gear and a posi. Motor is a 1953 331 Cadillac with 1956 2x4 Eldorado intake with correct wcfb carbs. Carbs definitely need rebuilt and might be cores. Motor supposedly came out of a running car but never seen it myself run. Engine has been sitting for over ten years. Trans is Out of a 55 Chevy , it’s a three speed with overdrive and is connected to the engine with a Bendtsen bell housing and aluminum flywheel with 10 1/2 inch clutch. 32 ford grill shell and radiator with AC condenser. Vintage air unit is mounted. Gas tank is custom built, it’s behind rear seat with and hot match fill cap in body reveal. Top has been chopped 3” and roof was filled with the intention of putting a stock looking roof material back on. 32 ford style dash. New Vega box but has not been mounted yet. Has all garnish moldings and trim. New door handles and window channels. Have all the material to make lake style headers. Has pretty much everything to finish it minus paint, interior and wheel choice. Does not come with rear wheels in pictures but will have a set on it if sold. Any other questions you can call or text me, Jeff at 641-990-8349.
