1930 Ford Model A traditional, nostalgic hot rod / street rod coupe “The Hollywood Howler” Professionally built by Shockley Customs, Fort Worth, TX around 2008-10 This nostalgic, classic 1960s era looking rod has only been driven 4000 miles since being built. After sold by Shockley Customs, the second owner had a completely rebuilt 354 cui Hemi installed in 2015 as well as a fully rebuilt TH350 transmission. (That drive train has less than 2000 miles on it.) The Hollywood Howler runs very good and strong, it has less than 2000 miles on it since the completely rebuilt Hemi engine and automatic transmission was installed. It is a smooth ride, steady on the road. I sit very comfortably in it with my 5.11ft with one hand loose on the steering wheel at 85mph. NOTE: The coupe comes with two set of wheels / tires. One set of tires has about 300 miles on them, and the current set has less than 50 miles since new. Body: All steel 1930 Ford. Chopped 4 ¼”, channeled 5” by Shockley Customs, Fort Worth, TX Louvered Rootlieb hood top, and louvered trunk (Seret Speed & Custom, Vallejo, Ca) Firewall (and engine) moved back 10” for better weight distribution. Hole drilled visor. Engine: 1956 Chrysler 354 cui. Bored to 392 cui and fully rebuilt less than 2000 miles ago. Isky camshaft, Holley 600 cfm, Aluminum intake. Mini starter. Re-chromed vintage Top Fuel valve covers and polished vintage aluminum breathers. Corvette style air cleaner. Transmission: TH350, 2200 rpm converter and 18” aluminum cooler. Chassis: 1932 Ford ASC frame, boxed, and shortened. 102” wheelbase. Tubular center for added strength. Model A front cross member. 1954 Ford F1 steering box. Front end: Chromed Super Bell axle, 4” drop. Chromed reversed eye leaf spring. (and one without reversed eye also included) Pete & Jake chromed shocks. 1940 Ford brakes. Rear end: 1969 Ford Mustang 9” rear axle. 3:50 ratio, Eaton Detroit True Trac, 31 spline Moser axles. Triangulated chromed four link, Adjustable QA1 coil overs. Aerospace disc brakes. Front wheels: 5.60-15 ProTrac blackwalls on vintage and polished 15x4” Ansen slot mags. and 5.60-15” US Royal, 1” whitewall . 15X5” chromed steel wheels with center bullet. Painted centers matching the car. Rear wheels: 9.00-15” Towel City slicks on 15x8.5” vintage polished US Indy slot mags. and 10.00-15” Radir slicks with whitewall. 15X8” chromed steel wheels with center bullet. Painted centers matching the car. Interior: White pearl rolls & pleat seat, headliner, door panels, roof insert and rear wheel wells. Dynamat under carpet and on the inside of the firewall Pinstriped 1936 Ford dash, Functional Stewart Warner gauges, 13 ½” vintage Superior steering wheel. Blue toned windows, side windows roll down, front window opens up. 1939 Ford steering column. 13” Lokar shifter. Seat belts, carpet. Paint: DuPont Mopar B5 metallic, all pinstriping, bordering and artwork done by Martin Kolor & Style, Napa, Ca Extra: Arrow 775 headlights, dual 1950 Pontiac taillights. 4 ½” sectioned grille shell, stainless grille insert. New chromed Mopar generator. 3000 cfm electric fan in front of Superior aluminum radiator. Loud exhaust with four chromed outlets each side. 11 gal aluminum gas tank. The center of all steel wheels painted and pinstriped by Kyle Martin of Martin Kolor & Style, Napa, Ca. Frenched antenna. Vintage BELL license plate frame. Call or email me for more information or / and pictures and videos. [email protected] 916-382 6464
