Projects 1930 Ford Coupe, another vintage hotrod salvage project.
Discussion in 'The Hokey Ass Message Board' started by stubbsrodandcustom, May 25, 2021.
  1. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    So we all know how much I like to punish myself with more work, but this little coupe just caught my eye. Bought it last weekend. So I am the 3rd owner of it, last titled in 1970. Texas car its whole life DFW area. Body is stellar in the rust department, rear trunk is perfect, only rust on body is passenger cowl lower. Bad part is its motor is toast, someone welded up a hole in the side of the block with a stick welder, few cracks here and there also along with one cylinder with 5 psi of compression, yeah probably stuck valves but cracked block probably wont ever be right. So trying to source another banger motor right now locally...
    Day one on the ride home...
    Tucked away for the night....
    Few other pics to give yall a good idea of why I had to have it...
    So let the games begin......
  2. Packrat
    Packrat
  3. mrquickwhip
    mrquickwhip
    I love it too.....great score
    nunattax and stubbsrodandcustom like this.
  4. catdad49
    catdad49
    Thank you for rescuing another A!
    Just Gary and stubbsrodandcustom like this.
  5. Wow, I love to find them like that. Anxious to see it come together.
    stubbsrodandcustom likes this.
  6. WB69
    WB69
    from Kansas
    Good score. Will make a great hotrod.
  7. Doug Hines
    Doug Hines
  8. Budget36
    Budget36
    I’ll be darn, I thought I was the only one with a bondo’ed block! 218 Dodge I had. My guy took extra care though and painted the block afterwards. Lol
    That looks like a great start you have!
  9. brading
    brading
    I am drooling, always wanted a Steel 5 Window Model A.
  10. mickeyc
    mickeyc
    I have an original A motor with a knock when running. I dont
    see any cracks? Now I have a replacement motor and should not need the
    one in the car now. Keep me in mind if you may be interested.
  11. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Thanks man, I will definitely keep it in mind, my buddy has a rebuilt motor thats been sitting 15 years never ran, I am trying to grab that but if he needs it then I may take you up on that, I have family in Morgan city so I can make a good road trip out of it.
    Stogy and chryslerfan55 like this.
  12. Model A Gomez
    Model A Gomez
    The crack is in the oil pan area and really wouldn't cause a problem except an oil leak from oil splash, JB weld fix on a running motor wouldn't worry me. Probably threw a rod at sometime but not near the water jacket and not really structural. Looks like a good body , will be a nice project.
    NoelC, Stogy, The37Kid and 4 others like this.
  13. rusty valley
    rusty valley
    Isn't it amazing how one day its they're pride and joy, then one day it gets shoved outside to die
  14. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Yeah, normally wouldn't worry me either, but I've got a cracked head and one cylinder with 5psi of compression rest at zero, so going to pull the head and see if we have some stuck valves or shot pistons etc...
  15. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Last nights update photos...
    So much easier to work without fenders etc in the way....
    Took a little time and got the head off... Only broke 2 studs....
    So interesting tidbit I have never seen in a block deck ever before... Anyone clue me in on this?
    Here is how she looks inside...No ridge hardly at all at top of cylinder, no real rust pitting in cylinders I have seen yet... No overbore stamping on top of pistons... I know its been into at some point in its life due to that repair on the side of the block... I've seen alot worse for sure...
    Okie Pete, Jet96, Stogy and 4 others like this.
  16. lake_harley
    lake_harley
    Cool start. Just in case other replacements for the repaired block don't work out, I have a good block as well as quite a few other Model A engine parts for sale. Downside is distance might be an issue since I'm in Southeast Missouri. But, send a PM if you have any interest.
    Looking forward to "in process" and "finished product" photos.
    Lynn
  17. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Update to start the new work week out...
    So we pulled the motor thursday. Went well.... Decided to tackle this front crossmember damage. Huge hole but no cracks, so made a new piece and welded it all in etc...
    Onto motor..... Brought it up to a buddy who wrenches on bangers some and had him give me the run down on how a few things come out as I have never removed valves in a banger. So verdict is block repair is great, welded inside and out, Babbitt is good on rods, everything was turned 10 thou when it was apart at some point. Standard bore cleaned up perfectly with a hone. Crank turns super easy, minimal endplay for thrust. I may have to pull main shims at some point but were not quite there yet... Valves took some major lapping but they cleaned up and sealed up good... He has some stainless valves but I am thinking of leaving these original since they are not cracked and show no real signs of failure other than a little rust pitting on the top of a few... Here are some in progress photos... The photos stopped when we had 4 head studs break off in the block... If that hadn't have happened we would have had the motor built in a day... So will go up friday and finish up hopefully...
  18. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Well, last friday was slow moving for sure. We got valves adjusted, few other things handled, then realized we had the wrong size rings. So here I am waiting on new set of rings... None the less, we dingle ball honed the cylinders, they look stellar.
    So the last few days got after cleaning the frame and some things up... Brush painted the frame with POR15, dang that stuff is shinny.... Not quite sold on shiny frame right now...
  19. Don't worry about the shiny - I used POR15 on my frame, and it will dull since it is not UV resistant (at least the stuff wasn't when I used it about 6 years ago). I am still happy with the results though.
    Looks great.
    Stogy and stubbsrodandcustom like this.
  20. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Were getting somewhere now.... New rings and put it all back together, now to rebuild starter, and a few other systems, find me a 94 carburetor to build and install and see if we can make some fire.
    Burns Speed Equip.
  21. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Progress has been a bit slower but still progress...
    So finally got the top wood kit in after 1 month...
    8 hrs to install, Alot of pushing, and prodding to get it back in...
  22. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    I am waiting on a carb now...
    But motor is ready other than a carb and studs... And wiring...
    Here she is in all her glory as of last night...
  23. timeflies
    timeflies
    from Guthrie OK
    Now that’s coming along great!
  24. Tim
    Tim
    from KCMO
  25. Blues4U
    Blues4U
    from So Cal
    Very cool! It got new wheels & tires somewhere along the way, looks much better
    Stogy and loudbang like this.
  26. The37Kid
    The37Kid
    Nice to see solid cars, found and brought back so quickly.
    Bob
  27. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Thanks...
    I had this set of 19s off my prior tudor sedan. I couldn't stomach looking at radials anymore on it..
    Stogy, loudbang and Blues4U like this.
  28. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Thanks.... I try to not let things sit and rot...
    I paid pretty good money for it, but it was more solid than 99% of the stuff around Texas for sure these days...
  29. SR100
    SR100
    I'm late to the party (as usual...), but flipping that image in PhotoShop produced this:
    Applying my best Google-Fu, I found one reference to a McCord Gasket Co ad in a 1935 Motor magazine, apparently listing part no. 5571 as a head gasket:
    Unfortunately, given its age, Google Books only posts it in snippet view. As has become common lately, the snippet they display has nothing to do with the text searched. Anyone have an old McCord catalog or volume 63 of Motor? Any guesses how it became imprinted?
    Okie Pete, Cooon, AHotRod and 4 others like this.
