30 roadster on a Deuce frame. 48 flathead with later model distributor. 39 three speed with quick change rear end. F-100 steering, 5" dropped & filled axle, square back spindles early ford brakes. New Firestones 550/16 and700/16. Other new parts. [brakes, master cylinder, lines, battery, cables, radiator, belts, ladder bars, wire panel, water pumps, headers, seat, drive shaft] 3" chopped windshield. The roadster is wired to run, I've driven it around the block a time or two. No other wiring has been done. The car has two part urethane primer on it now. Titled 1930 roadster in my name. Any question let me know, Greg @ 641 442 6071. No text or trades
