1930/31 Ford roadster in primmer Fenders and running boards in primmer 1932 original grille shell 1932 original radiator Tanks gas tank in trunk Dropped axle Four bar Chevy disc brakes 8” Ford rear Coil over Minivan seat Upper and lower stanchions Ford Wood tack strip Top irons Long block flathead Merc crank .60 over pistons Adjustable lifters Bronze valve guides Converted Chevy distributor Edmunds 2 deuce set up Flathead Jack C4 conversion Gennie shifter Clean Ohio Title Miscellaneous parts
