1929 model A sedan suspension
Discussion in 'The Hokey Ass Message Board' started by rimwrecker, Jun 10, 2012.
  1. rimwrecker
    rimwrecker
    from santa cruz
    Starting the build on my 29, I'm thinking of doing a transverse leaf in the rear along with coilovers to get a bit of both worlds: traditional look with a better ride and was looking for input
  2. Don's Hot Rods
    Don's Hot Rods
    from florida
    Use one or the other IMO, not both together. I think it would ride like solid suspension, even coilovers alone that are too stiff will ride harshly.
    In some cases it is best to not to try to reinvent the wheel. :)
    Don
  3. gimpyshotrods
    gimpyshotrods
    One, or the other. If traditional is the goal, get a NEW leaf spring, and some high-quality shocks, like Bilsteins. They have chrome ones, covered, and non-covered, and the stickers peel right off. Spendy, but WELL worth it.
  4. Do you wear a belt & suspenders?
    Decide on your requirements and pick one solution.
  5. The leaf spring will give you a fine ride if you remove a few leaves and install some teflon spring liner between the remaining leaves. My spring was originally 10 leaves and designed for rough roads with a flexible frame. I now have five leaves and a rigid frame. Also some regular tube shocks mounted at about a 20 degree angle.
