1929 ford sedan traditional hot rod
Discussion in 'Cars For Sale' started by goon56, Dec 22, 2015.
  1. goon56
    goon56
    from new jersey
    City: milford
    State: New Jersey
    Price: 30,000
    View attachment 3087710 putting a car up for sale for my friend. i built this car. started life as a stock restored 29 sedan. was restored around 1972 . no rust, or bondo or patch panels. repainted in stock paint. wood is perfect. plan was to make an east coast 1950 rich kid hot rod. frame was pinched and lengthened to make it spring behind to lower it without Z ing the frame. has an A spring in the rear with A shocks with custom links. frame is boxed. front axle is a 5 inch mugnum. with posies spring. rear axle is fresh rebuild 64 mustang with 4.11 gears. hung by pete and jakes triangulated ladder bars. front brakes are new speedway big ford brakes. motor is a 53 flattie freshly rebuilt with truck cam. offy heads and duel carb intake with 2 nos holly 94 ontop. hand built beautiful headers. bellhousing adapter to s10 5 speed just rebuilt. hydrolic clutch. pete and jakes brake and clutch combo. body was channeled to bottom of frame without messing with the body and everything is disassembleable. fit and stained wood floor. seats were redone. eliminated the springs in em. and memory foam was used and stock covers installed. cool part is that passenger seat still folds foreward to gain access to the full rear seat. rear seat is still full functional. battery box and fuse box is behind the seat but the car can still seat 4. the car is super comfy. not like when u drive a rod for ten minutes and feel like you've been driving it for 4 hours. car has custom radiator to retain the hood. wheel base is exactly the same as stock. still uses the cleaned out, no rusty gas tank. new coker tires and steelie wheels. alot of work went into this car. theres about 30 miles on this car. everything works . all wiring is 12 volt. generator. even has original ahhhoooga horn with voltage regulator. cigarette lighter. custom short column by lime works. any more questions just ask. have all the receipts. clean title . registered and insured. car has been buffed out and cleaned since photos
