I am looking for the firewall and passenger door post tags for a 1929-30 Dodge Brothers 4dr sedan . If anyone also has the rad emblem and wheel nut grease covers for the above that would be appreciated. Thanks Rob.
Which model sedan '29-30? There's DA, Senior Six, Victory Six,Standard Six, DD, and DC. The serial number would be on the floor board at the passenger's feet and stamped on the frame. I think the frame stamp is on the passenger's side behind the front axle's rear shackle.
noboD, thanks for the info I hope you don't mean the wooden floor board as there aren't any, but I will look in the other locations. Thanks Rob
vin tags should be on the pass side "b" pilar,and the #s on the frame should be on the drivers side face in between the cowl and the front axle.
My 29' DA four door has frame #s stamped on the top of the pass. side frame rail about 12" from the firewall as well as a plate on the floor toe board pass. side.
