1928 Ford Model A hot rod Coupe. Solid original steel body. Chopped top. The frame is fully boxed and kicked in the rear. New custom built steel floors. New dropped axle up front. New split wishbones. Late model Ford rear axle. Steel 1932 ford grill, new aluminium radiator. Updated headlights wiring. All new glass. Has all original garnish molding chopped to fit. New custom cut and balanced driveshaft. Ford 292 y-block, rare Offenhouser tripower intake and three rebuilt 2 barrell carbs and progressive linkage, rare weiand finned valve covers and ram horn manifolds. Dual exhaust. Transmission is a new T5 with hurst floor shifter and willwood clutch setup . custom covered leather bench seat. New steering column and vintage steering wheel, Old school Stewart Warner gauges all function as they should. Semigloss black paint. Ford steel wheels. Firestone wide whites New wood kit for the roof. Oversized fuel tank and battery in trunk, new sending unit installed. Running Ford juice brakes. This car runs and drives great. Clear title. This coupe is an original AR coupe. One of the first prototypes built by Henry Ford before production was started. Very rare car 25k CALL 205-272-4539
