1928 chevy 4cyl motor
Discussion in 'The Hokey Ass Message Board' started by RedRodder, Apr 7, 2010.
  1. grumpy gaby 2
    grumpy gaby 2
    You lucky dog! Thats the best that I've seen in a long time!
    Dan Morrison likes this.
  2. Six Ball
    Six Ball
    from Nevada
    I agree! I wish I could find one that nice. Does the other side look that good? The wheels look good too. Les Schwab has a powder coating service where they blast the wheels before they coat them. The price was good so I had my 19" wheels done. I'm not a real fan of powder coating but these came out nice.
    Dan Morrison and grumpy gaby 2 like this.
  3. Dan Morrison
    Dan Morrison
    Yes both sides of the radiator look really good and it doesn't seem rotten, but I haven't tried it yet either. Just a fluke I spotted it. I went there for wheels, I needed the radiator worse than I needed the wheels. 3 of the wheels are decent, one laid in the dirt too long and is toast. Many years ago I was helping my dad load a shed full of mostly Model A parts he bought and we left 6 beautiful Chevy wires behind cause he didn't want them. I wish I could remember where that was. Anyway I enjoyed the trip, made a new friend, and got more old car parts. Can't get much better than that.
    Six Ball and grumpy gaby 2 like this.
  4. Six Ball
    Six Ball
    from Nevada
    Stick together Chevy Boys!
    grumpy gaby 2 likes this.
  5. Dan Morrison
    Dan Morrison
    The holy grail of speedster radiators! I drove almost to Lake Erie to get this .... over 12 hours in the truck today ... I had already made a deal when I found the 26 radiator the other day. The shell needs a lot of repairs ... always wanted one of these ... decisions decisions.... I will probably have to sell a kidney to pay for a recore if it's bad. I think it's a 26, not positive on the Whippets. IMG_20231004_173154183.jpg
    bct and Six Ball like this.
  6. nrgwizard
    nrgwizard
    from Minn. uSA
    28-29. They look earlier, but aren't. Only made from 28-31.The other rad style looks sorta like a modelA, just wider n taller. Got 1 of each, debating on how they're going to get used, if they are.
    Marcus...
    Six Ball and Dan Morrison like this.
  7. Dan Morrison
    Dan Morrison
    Question for the experts. The rear transmission crossmember that was added in 1926 - what years are the same? We have touched this before and I think 28 is different, taller maybe. Are 26-27 the same?
  8. grumpy gaby 2
    grumpy gaby 2
    I think that the 27 is also different from the 26. To verify this I will have to cut out a cave in 25 feet of black berry brambles! I am getting VERY TIRED of cleaning shop, and it is a nice day, so maybe I should try it!
    BUT I AM NOT AN EXPURT!
    Six Ball likes this.
  9. grumpy gaby 2
    grumpy gaby 2
    Well got the tunnel chopped out! No trans. or crossmember in the 27 parts car! Dang! Now to try for a plan 2.........
  10. Six Ball
    Six Ball
    from Nevada
    GG2, Why doe we even try to work in cars when there are so many fun things to do around our places? My new inner tube came yesterday. I got it on today. Road work restarts in the morning.
  11. grumpy gaby 2
    grumpy gaby 2
    INNER TUBE! What happened to you? Big $$ or little $. How much road do you have left?
  12. grumpy gaby 2
    grumpy gaby 2
    Dan, plan 2 did not work. I did find two 28's and one 26 that had a 25 trans. attached to a 25 steel bell. (the 25 shift rods come out the front of trans. and bell.) Bet they used a torch on the cross member!
    Plan 3 will be to get into the speedster and pull the floorboards, but that is going to be another day.
    Dan Morrison and Six Ball like this.
  13. Six Ball
    Six Ball
    from Nevada
    Front tube 6.00x14. Got in a pole of rocks and ripped the valve stem out. Changed to on my Harbor freight tire mounting thing. I have about 1/2 of the road roughed in. I is the worst 1/2 though. :)
  14. grumpy gaby 2
    grumpy gaby 2
    Whew! I was afraid that it might be a rear! Good luck on the rest of that road!
  15. Dan Morrison
    Dan Morrison
    Grumpy, thank you for trying. Maybe you could just tell me, if I got one for a 28, would it be feasible to cut out a piece with my plasma cutter and weld it back together so that it would fit my 26 chassis? I wish you all were close by where I could ride over and visit
  16. grumpy gaby 2
    grumpy gaby 2
    Dan, I think that you could. On speedsters and hot rods anything can be done! RIGHT! I found that my late 26 roadster frame has a 28 Transmision and crossmember in the 26 frame. I tried to get a good measurement but could not. I know that it is over 1" and under 2" miss aligned. I will have to use something like centering punches to get a 'caliper' measurement. I will get a pic. of this when I can.
    One thing to worry about is the alignment of the peddles and cutout in the crossmember on the driver's side.
    The other thing is to tack it back together in the frame that has been checked for tram and is level. Myself, I would set an engine block with the front mount and cast iron bell into the frame, align and bolt down. (the cast bell and engine are dowl located also the cast to pressed steel are doweled. The presses steel bell is located to the crossmember with two shoulder bolts. Mount the ends of the crossmember to the frame with the spacers, check peddle movement, (clutch peddle swings into hole, brake rod goes over crossmember I think!?) and build the connections. P.S. don't pay much for that 28 crossmember, they're very easy to find!
  17. Six Ball
    Six Ball
    from Nevada
    The variety of crossmembers that are part of the engine & transmission mounts in the '25-'28 Chevys is a study of its own. So many of them look to be the same at first glance. :confused:
    grumpy gaby 2 and Dan Morrison like this.
  18. Dan Morrison
    Dan Morrison
    Yes, most of the mounts I find for sale are ‘28. I might be able to source a 28 locally. If I had just thought of it, I could have probably got the crossmember with the frame, didn’t think of it and didn’t know there are that many different ones. I am not even sure the transmission I have is useable, if I go with a later transmission, then the crossmember will probably be a whole other issue. I kinda wanted to start with everything basically stock, then make modifications. One other question, did the 28 ton trucks use that crossmember?
  19. grumpy gaby 2
    grumpy gaby 2
    Got some pics. and marked up. Dam! lost markups!
    All are 26 frame with 28 crossmember except last is 26 crossmember.
  20. grumpy gaby 2
    grumpy gaby 2
    found one marked up.
  21. Dan Morrison
    Dan Morrison
    Thanks for those pictures, that really helps! I was expecting the 28 crossmember to be the taller one. With those pics I think I can identify a 26 crossmember if I see one.
  22. grumpy gaby 2
    grumpy gaby 2
    Dan the 28 also has two holes on the bottom flange to mount the brake switch, the 26 does not have.
  23. Dan Morrison
    Dan Morrison
    There are four crossmembers on eBay right now. Shipping is the issue. They all appear to be 28 style. Looking at the pics, it might be easier to rework the frame mounts than to modify a crossmember.
  24. Six Ball
    Six Ball
    from Nevada
    I thought those cross members went all the way across and bolted directly into the frame rails. In the picture it looks like there is a fixture on the frame that they bolt to.
  25. Dan Morrison
    Dan Morrison
    My 26 frame has mounting pads like in the picture. From what I can tell from pictures and parts for sale, there is a shim about 1/4 inch thick that goes between the pad and the cross member, then bolts with nuts and washers hold it in place.
    grumpy gaby 2 and Six Ball like this.
  26. CRAIG ADAMS
    CRAIG ADAMS
    I agree that Whippet Grills are great, but I want to use just Chevy parts on my 27, so!
  27. CRAIG ADAMS
    CRAIG ADAMS
    Early 50s chevy 4 door rusted out rear fender.
  28. Six Ball
    Six Ball
    from Nevada
    So far my '26 roadster has Chevy, Studebaker, & Jeep parts. There is an Olds steering wheel if I can't use the Chevy one.
  29. Dan Morrison
    Dan Morrison
    My original plan was to build a Fordolet speedster consisting of a model T chassis with a Chevy head on a T block with a Chevy crank, disc wheels, front spindles, and headlights. However I kept finding Chevy parts. At one point I considered using the whole Chevy engine in a T speedster. I think the T chassis is lighter. After seeing pictures of a 1926 Chevy with a Mercury body, the die was cast. I might not use the Whippet radiator, I don’t know yet, but I do like the look. If it is good enough for John Gerber’s race car, it’s good enough for me. Here is a pic of Gerbers Chevy powered racer with the same style Whippet radiator.
  30. Six Ball
    Six Ball
    from Nevada
    If I had a good Whippet shell I think I'd use it. I really like the look. Even Spurgin-Giovanine ran one for a while.
