1928 "A" Roadster pickup with V8 - 60hp
Discussion in 'Cars For Sale' started by Gary in MN, Apr 3, 2019.
  1. Gary in MN
    Gary in MN
    City: SAINT PAUL
    State: Minnesota
    Price: $ 12,000
    1928 Model A Ford Roadster Pickup V8 60 HP
    Engine: 1938 "cast iron side" V8 60 HP. Complete rebuild with NOS pistons, rings, con rods, main & rod bearings, valve springs, keepers, camshaft gear, oil pump gears. Used camshaft, repro cam bearings, oil pickup tube and screen. Repro fuel pump, rebuilt starter and generator. Rebuilt "48" Stromberg. Crankshaft ground to .020/.020
    Trany: Resufaced cup style flywheel. NOS Pressure plate, starter ring, clutch plate, throwout bearing and collar. Used small 60 HP trany case, shift tower and forks. The internals are NOS, gears, shafts, bearings and u-joint.
    Rear axle: Axle came out of a running and driving car, 4.11 ratio. Torque tube, radius rods and driveshaft shortened to fit the "A" frame. Rebuilt "A" shocks front & rear. New rear spring, 5 leafs. Rides nice.
    DSC00919 (300x169).jpg DSC00924 (300x169) (4).jpg DSC00929 (300x169).jpg DSC00926 (300x169) (3).jpg
  2. Gary in MN
    Gary in MN
  3. Gary in MN
    Gary in MN
  4. Gary in MN
    Gary in MN
  5. Gary in MN
    Gary in MN
