Technical 1928/29 model a roadster on 32 rails wheel wells
Discussion in 'Traditional Hot Rods' started by dougbroom, Jul 21, 2019.
  1. dougbroom
    dougbroom
    looking for pictures of where the frame starts to tuck up into the body . close ups and inside shots , and pictures of replacing the wheel wells in this application thanks
  2. oj
    oj
    I think most people pinch the frame, if you are fenderless the inner fenderwell reveal is out where all can see it and builders go to great effort to keep them as stock looking as possible,
    Texas Webb likes this.
  3. redoxide
    redoxide
    from Scotland
    Im just about to do this with my 30 coupe.. will post up some pics as I go .. hope to make a start on Monday .. perfect timing..
    The 28/29 cowl is narrower than the 30/31 but from replacing the sub rails the rear end is pretty much the same width as the earlier cars..
    This thread might be a big help to you : fella is just about to start the build..
    https://www.jalopyjournal.com/forum...uce-rails-can-aus-build-thread.1122528/page-2
  4. This my '30 roadster but it should be the same as the 28/29. This is what I am working on right now. More details on build thread.
    The front 7" and the rear 4-1/2" remain the same as original. The kick up goes in between
    I modified the wheel well to follow the same flow as the frame.
    The two green lines below, the bottom ones is the top of the frame and the top one is the top of the subrail.
    Frame tucks underneath/behind the panel in front.
    The panel ends straight at the back to attcjed to the rear crossmember, just as the stock one.
    From the inside the wheel panel sits flush agains the rear subrail and the rear brace attaches to the panel, same as stock.
    clem, dwollam and redoxide like this.
  5. Atwater Mike
    Atwater Mike
    The side subrail looks fabricated, rather than 'rolled'...Beautiful fit there, most leave this area to 'any way they can attach it'.
    Any pics of the side subrail's beginnings? Very sharp, great fit of body to side rails.
  6. Dino 64
    Dino 64
    from Virginia
    On my 31 coupe, used Steadfast sub rail kit.[​IMG][​IMG][​IMG][​IMG]
    Just followed the curve of the sub rail to trim the wheel well. Hope this helps
    akoutlaw and Just Gary like this.
  7. dougbroom
    dougbroom
    thanks
    Dino 64 likes this.
  8. 1946caddy
    1946caddy
    from washington
