1927 Ford Model T Roadster TOP QUALITY CUSTOM.
Discussion in 'Cars For Sale' started by Apsencik, Feb 3, 2016.
  1. Apsencik
    Apsencik
    City: Gonzales
    State: TEXAS!
    Price: 39,900
    Professionally built by Jesse James and Bob Bleed of Austin Speed Shop and International House of Hot Rods in Austin, Texas.
    Over $80k of receipts and it shows in this beautifully customized build that was done very tastefully.
    Custom powder coated frame
    Speed way motors front end
    Speed way Carrera coil over rear suspension
    Front and rear hair pin frame connectors with super duty attaching brackets
    Real Deal Ford steel body WITH VIN on front fire wall.
    Original rear tail gate patina - this was a REAL 'gas truck' at some point.
    Entire body lizard skinned inside and out - NO rust will ever get on the body as long as the car is taken care of.
    388 cu engine that runs great. Built by Kenny of IHOH
    9.5:1 compression
    Eagle forged rotating assembly
    Vortec Heads with roller rockers
    Powder coated block and heads
    Dyno Sheet proven 390 HP/ 435 ft. lbs TORQUE.
    custom Walker radiator
    electric fan
    Holly 750 double pumper avenger carb. Works perfect.
    700 r4 transmission with complete rebuild.
    Ford 9" rear with complete rebuild and Mosier axles.
    Professionally wired and hidden very well
    Master cylinder hidden inside frame under driver seat
    Custom brass duvall windshield and glass with custom rake
    Custom stainless pipes and brass stabilizers in shape of bare knuckles
    Interior by Marios Interiors of South Austin. Notice the gold piping for classic 60's look.
    Stewart Warner gauges. (fuel doesn't work as there's no sending unit hooked up currently)
    Custom fuel tank
    Custom removable steering wheel
    Turn signals inside cab on dash and on headlights
    Custom metal flake candy purple paint ($15K)
    Custom rocket igniter wheels and Coker tires for more of that true 1960's look.
    Lokar shifter with matching leather boot.
    Custom pin striping by Darren Wenzel.
    This car was worked on by the best of the best in Austin Texas area.
    This is truly a craftman's car.
    All work can be verified via receipts and tons and tons of pictures.
  2. Apsencik
    Apsencik
