Projects 1925 Chev Roadster Build, 2 are better than 1...
Discussion in 'Traditional Hot Rods' started by Jimmy B, Nov 2, 2020.
  1. Tim
    Tim
    from KCMO
    Nice! Looking great so far
    loudbang and Jimmy B like this.
  2. Now to the crossmember I tried to get the radius rod mounts as close to the torque tube as possible, Chevs used a slip joint bell at the front. I had thoughts of making this like a ford torque tube but I think it won't be strong enough hence the way I have gone. With the wishbone rubber and slip joint there should be minimal bind.
    IMG_3961.JPG IMG_3962.JPG IMG_3965.JPEG IMG_3966.JPG IMG_3967.JPG IMG_3968.JPG IMG_3971.JPG IMG_3972.JPG IMG_3973.JPG IMG_3974.JPG IMG_3975.JPG IMG_3976.JPG IMG_3977.JPG IMG_3978.JPG IMG_3979.JPG IMG_3980.JPG IMG_3981.JPG IMG_3982.JPG IMG_3983.JPG IMG_3984.JPG
    That is all I could do with the crossmember without having a second pair of the wishbone mounts. Good news they will be ready next week so should have them in a couple weeks
    Outback, 40two, Okie Pete and 7 others like this.
  3. Next I bit the bullet and purchased a lathe, I tried to find a vintage lathe to no avail, so...... only option was chinese :mad::(
    I moved on to the shock mounts, I turned these pins to go thru the original spring mounts, with the space being limited the covered shocks I purchased won't work so will go with the non cover shocks.
    IMG_4034.JPG IMG_4037.JPG IMG_4038.JPG IMG_4044.JPEG IMG_4045.JPEG IMG_4046.JPEG IMG_4047.JPEG IMG_4048.JPEG IMG_4049.JPG IMG_4050.JPG IMG_4051.JPG IMG_4052.JPG IMG_4053.JPG IMG_4080.JPG IMG_4081.JPG
    Outback, Okie Pete, brEad and 9 others like this.
  4. This is kind of where I am at, just waiting on a few parts and also need to take a few pics of some smaller jobs I have done.
    loudbang and Stogy like this.
  5. Tim
    Tim
    from KCMO
    Bet that lathe will prove to be a fantastic investment.
    Are the bracket side of the shock mounts Chevy spring hangers from the base chassis?
    Jimmy B, loudbang and Stogy like this.
  6. The lathe has come in handy and have many more ideas to try out.
    Yes I removed them from the chassis, these brackets are the rear hanger for the front end.
    brEad, loudbang, Stogy and 1 other person like this.
  7. Stogy
    Stogy
    When I purchased my Sport Coupe the rear tube shocks were upside down to clear the larger cover that was fouling against the crossmember...I managed a work around as I see you have...so many hurdles...​
    Outback, Jimmy B and loudbang like this.
  8. It is always a challenge trying to get things to work in confined spaces, as you say there are always work arounds, solutions. Part of the enjoyment in building these cars, I actually enjoy the challenges, it get frustrating at times but the effort in the end is worth it.
    Outback, loudbang and Stogy like this.
  9. So I thought I would do a quick post with some other projects I am collecting for. I picked up a '27 T RPU in September 2019, I am glad I was able to get it given how 2020 has turned out.
    Then in October of 2019 I purchased a lot of '29 parts to replace the parts I sold in 2010 to help fund my first US trip.
    While I was in the US in January I purchased a few panels for future projects '30 Model A cowl top and firewall and a '25 T cowl top. I now have a '25 T firewall, cowl top, L & R doors, door hinge & brace, windscreen posts, decklid and the front portion of the turtle deck. Next step will be to build a body buck for the T, I will start a thread for that once started.
    Outback, Okie Pete, brEad and 8 others like this.
  10. grumpy gaby 2
    grumpy gaby 2
    Jimmy B It looks you're going to be a busy builder!!!!!
    Stogy, Jimmy B and loudbang like this.
  11. continentaljohn
    continentaljohn
    Sweet build and you sir are a craftsman
  12. Yeah got to keep occupied. Plus it always helps to think ahead to the cars I want to build as the delay in ordering parts sucks!
    Outback, Stogy and loudbang like this.
  13. Thank you John!
  14. Parts arrived yesterday so I may start the ‘25 T body buck soon.
    Outback, Okie Pete, brEad and 5 others like this.
  15. Kume
    Kume
    what motor are you putting in the T roadster?
    Stogy likes this.
  16. '25 T will be v8-60 (Simca) or whatever flathead v8 I can find.
    '27 T RPU will be SBC.
    Outback, Okie Pete, Stogy and 3 others like this.
  17. I received the second set of wishbone mounts from Adam Tremellen. I purchased this set for the rear radius rod mounts. I am in the middle of a shed rearrangement so will get back to the chassis sometime this week.
  18. Looks great.
    Stogy, loudbang and Jimmy B like this.
  19. 48fordnut
    48fordnut
    They look amazing. Good luck.
    Happy Thanksgiving.
  20. Jimmy B,
    I am LOVING your build: Real creativity and talent showing here!
    Those wishbone mount kits are Super Cool!
    Do you have the contact info for Adam Tremellen?
    I would like to get a kit.
    Thanks,
    Gregger
  21. Thanks!
    Thanks and Happy Thanksgiving to you too!
    @Gregger Rod & Custom
    Thank you Gregger! Are you on Facebook? If you are PM me and I will send a link to Adam's FB profile, I don't like putting contact info on a Public forum.
    Outback, Stogy, loudbang and 4 others like this.
  22. 39custom
    39custom
    Excellent work. :):)
  23. chev34ute
    chev34ute
    It’s interesting seeing all the panels you have gathered. I have been wanting a 27 T Roadster body for ages but don’t have the funds so I have done a deal. I am building a 28/29 Model A Coupe roof in exchange for some 27 Roadster panels for a mate near Sydney.
    Outback, Stogy, Jimmy B and 7 others like this.
  24. Okie Pete
    Okie Pete
    Amazing skills . Thank you for taking us along the path of your builds.
  25. Pete Eastwood
    Pete Eastwood
    from california
    Who makes these ?
    Outback, kidcampbell71 and loudbang like this.
  26. AmishMike
    AmishMike
    Nice wishbone mounts, looking forward to where on frame & how mounted
  27. Thank you!
    I like to collect early and time the build comes around I can start and make whatever I don't have. Good you have a way to trade for a T, nice work on the back roof panel! I would love to get a turtle deck, I have seen 2 Oz T roadsters for sale in last 12 months but too much and too far away. I traced a T quarter while I was in the US in Jan/Feb, I will work with that and the body to build a buck.
    Thank you! & I am happy people are enjoying the build.
    @Pete Eastwood Adam Tremellen makes them down in Victoria Australia. I will PM you a link to his FB.
    They are really nice. Hopefully I should have an update by this weekend.
    loudbang and Okie Pete like this.
  28. I recently purchased another 3-port, this one was modified in 30s or 40s. This will go on my current build. :D:D
    Outback, Stogy, Okie Pete and 2 others like this.
  29. Six Ball
    Six Ball
    from Nevada
    So how have I missed this? You are going to have two done before get my body together.
    I just went through all of this but I will do it again. Lots of great work.
  30. grumpy gaby 2
    grumpy gaby 2
    I see someone got the cooling holes in the back corner already! Really punched out the intake runners! (must be about max...) GOOD FIND!
