do they make a 15 inch rim that will accept a 14 inch hub cap? my 59 ford has its original hubcaps and i would like to keep them but its getting harder to find tires for them.
.I think youll find tires before you find any wheels like that... You just havent looked very hard for tires..Try Coker
'59 caps? If they were '57 type, I could see it. Send Wheelkid a PM. He and his Dad make hub cap adaptors for many makes, (mostly the small center types) I should say he will find a solution. Monsterflake's suggestion should be considered; the caps might clip onto the beauty rings. If not, do like he says: "Screw it"!
http://www.imperialclub.com/~imperialclub/Repair/Wheels/convert/index.htm Old thread, I know, but here's an interesting fix. This guy cut apart 14 inch rims and welded the hoop into 15 inch rims.
Please don't do that. Have the wheels cleaned up and either spray with clear are have them powder coated.
