Hot Rods Firewall Gauges
Discussion in 'The Hokey Ass Message Board' started by Ryan, Mar 13, 2023.
  1. Ryan
    Ryan
    ADMINISTRATOR
    Ryan submitted a new blog post:
    Firewall Gauges
    orbitup, AHotRod, dana barlow and 9 others like this.
  2. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
  3. Moriarity
    Moriarity
    SUPER MODERATOR
  4. deuceman32
    deuceman32
    The last photo is pretty interesting. Aside from the killer set of crescent needles apparently set into white naugahyde, there's a lot of chrome, some unique headers, a magneto and then that induction system.
  5. Just temp and oil pressure...but I liked having them while tuning/running the engine. 20220620_155643.jpg
    jazz1, sewfast, AHotRod and 24 others like this.
  6. Ryan
    Ryan
    ADMINISTRATOR
    This is the application I like. Simple and functional for one-man tuning purposes.
  7. Taken at last year’s LSRU at the Top Notch B3937656-D39B-4441-BFE8-2C4625F11594.jpeg
    Cosmo49, EVL401, AHotRod and 10 others like this.
  8. Two that come to mind. The first car I remember seeing with firewall mounted gauges was Bob Bleed's family roadster @bobbleed
    Darth Walter Coupe @Dreddybear
    EVL401, AHotRod, hfh and 14 others like this.
  9. Automotive Stud
    Automotive Stud
  10. TexasHardcore
    TexasHardcore
    from Austin-ish
    I've never had them on the firewall, but Oil Pressure, Water Temperature, and Vacuum gauges are always in my engine bays, usually direct mount liquid filled.
    Kevin Ardinger and XXL__ like this.
  11. Hot Rods Ta Hell
    Hot Rods Ta Hell
    I love the look and functionality of them. It captures both the show car vibe as well as the performance look. It indicates the driver is a wrench and cares about his mill.
    Ryan, the lighted set you posted are rad.
    To complete the "one man tuning" show, I've got the ignition switch mounted on the far left side of the dash. Open the suicide door, hit the key with my right hand while I dick around with my left with the throttle linkage or distributor.
    I always wondered if there's any accuracy loss running two mechanical gauges (oil pressure, vacuum) off the same line?
  12. catdad49
    catdad49
    It makes perfect sense, so why aren't more doing it?! Tach, oil pressure, and maybe a vacuum gauge.
    longhorizon and Muttley like this.
  13. Bandit Billy
    Bandit Billy
    My flathead has mechanical oil pressure, water temp and fuel pressure. Direct mount not firewall but I do like the firewall mounted gauges on a open hood car.
  14. Tim
    Tim
    from KCMO
    mad mikey, chryslerfan55 and El Hueso like this.
  15. The Trendero. https://kustomrama.com/wiki/The_Trendero
    EVL401, AHotRod, dana barlow and 4 others like this.
  16. Lostnot
    Lostnot
    Bob & Carl Austin's '48 Merc powered '27 T roadster from Rochester NY - 1959
    EVL401, AHotRod, Atwater Mike and 4 others like this.
  17. Moriarity
    Moriarity
    SUPER MODERATOR
  18. pwschuh
    pwschuh
    C'mon guys... a REAL hot rodder has a speedometer on the firewall... because why not !?! :eek:
  19. I'd like to see a dash-mounted gauge cluster that you can pop the whole pumpkin out, turn around and set down on the cowl........ then shove it back into the dash when you're done messing with the engine.
    I'm not sure if I want one but I would like to see one. :rolleyes:
    catdad49, Ned Ludd and chryslerfan55 like this.
  20. catdad49 and chryslerfan55 like this.
  21. Besty34
    Besty34
    always fit them, just think they are as cool as you like IMG_2073.jpeg IMG_0565.jpeg IMG_0887.jpeg
    osage orange, EVL401, AHotRod and 7 others like this.
  22. Stoner
    Stoner
    This one at LSR last year...
    EVL401, AHotRod, hfh and 6 others like this.
  23. lostone
    lostone
    from kansas
    I could see a tach and a vacuum gauge for doing the tune-ups, really don't see the need for oil and temp unless your having some kind of mechanical problems.
    A small oil pressure gauge on the motor, a small fuel pressure gauge on the fuel block would be fine.
    Not saying I wouldn't do it but the oil and temp gauges to me are more for show than go.
  24. 327-365hp
    327-365hp
    from Mass
  25. jaw22w
    jaw22w
    from Indiana
    I have thought about installing firewall gauges several times in my T coupe, but never followed through. I love gauges. My T has 6 in the dash, 2 on the column, and a fuel pressure gauge at the carb. I love to tweak and tune on engines. Probably the main reason I have been a racer/ hotrodder my entire life. So, I would want the firewall gauges I need when starting a new engine or tuning on an old one. Tach, oil pressure, and temp gauges would be my first choices. I also use a vacuum gauge quite a bit, but 4 gauges seems a little too much. And a vac gauge is easy to plug in when you need it.
    Someone mentioned earlier about a starter button on the firewall. That would be really handy.
    A kill switch would be easy.
    My question is, are the electrical oil pressure and temperature sending units capable of supporting 2 gauges? I have never tried running 2 gauges off one electrical sender. Does it work?
    I'm pretty sure the extra tach will work just wired off the coil, because my dwell/rpm meter does. My vacuum gauge is manual, so the extra vac gauge can be T'd in if I decide to use it.
    Maybe it's time for firewall gauges.
    Thanks for posting that Ryan!
  26. partsdawg
    partsdawg
    from Minnesota
    If you like the look...Do it.
    If you don't...it ain't your car so respect the owners choice.
    There are a number of traditional hot rod or kustom traditions I don't care for and I wouldn't do to my car but if it floats the owner boat I'm happy for them.
    Cosmo49, Driver50x and impala4speed like this.
  27. The drag coupe has some, been there since the 60's. WIN_20170423_12_34_39_Pro.jpg
    EVL401, AHotRod, Driver50x and 5 others like this.
  28. A godsend when working alone under the hood. Warning lights on the dash, ala the old style VW bug speedo.
    EVL401, AHotRod, hfh and 8 others like this.
  29. Hollywood-East
    Hollywood-East
    osage orange, EVL401, AHotRod and 5 others like this.
  30. Chris Flynn’s model A pick up runs them well. This is an incredible build with all kinds of cool details.
    200E084B-F5E9-4129-9FD0-2E60EFADB089.jpeg D0F8CBA0-6737-4E02-9D3C-3C2C22FF1084.jpeg 306431FA-9E0E-4F5B-847F-FA41215C32DE.jpeg 5B15B069-3274-4305-9C31-65DF8B354A70.jpeg 3730F54C-8A9F-49F5-BBCF-8844097E7BCB.jpeg
