Customs Hidden Fuel Fillers
Discussion in 'The Hokey Ass Message Board' started by Ryan, Oct 25, 2021.
  1. Ryan
    Ryan
    ADMINISTRATOR
    Ryan submitted a new blog post:
    Hidden Fuel Fillers
    Okie Pete, 41 GMC K-18, Tim and 5 others like this.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    Age old custom trick is to put it in the trunk
  3. Ryan
    Ryan
    ADMINISTRATOR
    Yes sir… that’s where it is in the Pratt shoebox…
  5. Yep Taboo is the same way, routed into the trunk. Its cool and a pain as all the local pumps now have those rubber boots and are hi flow so its pretty much a 5 gallon can at a time at home if you want to drive it and then get out of the city to find bootless pumps.
  6. wheeldog57
    wheeldog57
    The boss looks like he has most of the cool ones covered. That custom fuel door on the 55 is neato!! Let's see some more.
  7. I was cleaning up in the shop and found a fuel door and fender section I saved from a 911 Porsche. I was in my 20s when I saved this piece from a car I fixed in case I wanted a clean filler door.
    As I’ve gotten older, those visual lumps and bumps from the cab mounted gas tanks bother me less and less.
    That hinge mechanism could be used on a tail light though....... hmmmmmm
    on a side note, we went from a gas filler in plain sight to hiding them behind doors. Then we shaved the doors and hid em in trunks or beds. We’re setting up a filler in the bed of a truck at school now. A student asked why we shaved the gas door. I didn’t really know how to answer that.
    Okie Pete, firstinsteele and Stogy like this.
  8. squirrel
    My brother's 59 caddy was hard to find....but that was years ago. Here's someone elses 59 caddy
  9. Hot Rods Ta Hell
    Hot Rods Ta Hell
    D2539226-0C2D-4D46-9DBE-824D33E92F6C.jpeg D2539226-0C2D-4D46-9DBE-824D33E92F6C.jpeg Another cool feature of 50's cars! The cap behind the rear license plate made a ton of sense, prior to long reach pump hoses as most cars had the filler on the drivers side. People would line up on one side of the island vs. driving around to the other side. Working in a service station during High School in the mid 70's I knew which 60's/70's cars had plate caps and would wave full service customers into both sides of the island to get them pitted.
    There's a co. that makes a motorized 55 Chevy taillight kit.
    Kindigit did a 52 Pontiac build where they bonded the stock quarter panel emblem to a hidden flush mount gas cap. It's spring loaded, so a push on the emblem pops it out, then you unthread the cap. Pretty cool.
  10. goldmountain
    goldmountain
    I loved trying to find where they were hidden when I was a kid. I would walk over and flip them open. The owners were probably not impressed.
    Okie Pete likes this.
  11. TrailerTrashToo
    TrailerTrashToo
    I remember those. I was a freshly-minted college dropout in January of 1964. My new job was a "Pump Jockey and general flunky" at the full service corner gas station. Fortunately, I was a gear-head, so the learning curve was shallow.
    Some observations from that job:
    1. Not only was the gas filler hidden, finding the hood latch was a challenge.
    2. I did manage to learn about jump starting Positive-ground Fords (and did not let the smoke out!).
    3. New England winters can get extremely cold - My hands never totally recovered from that frostbite...
    4. Minimum wage jobs (54 hours/week - not eligible for overtime) are not very fun (Work is a 4-letter word).
    5. Occasionally, something cool would show up, such as an air-cooled Franklin, or an old Dodge cattle truck. Amd lots of retired folks that actually needed your best full service efforts.
    6. And weird stuff, like the guy with the VW beetle that wanted a receipt for 20 Gallons of gas.
    7. Or the 409 Chevy. The teen aged son would come in on Saturday morning and have me turn up the idle. Then the father would come in on Monday - All pissed off - and have us turn the idle back down. Found out the station owner had ZERO mechanical knowledge (he was unscrewing the pivot screw on the choke linkage...).
    EDIT: Those GM behind-the-license-plate fillers would sometimes slosh out some gas as the driver accelerated away from the pump.
    Russ
    Okie Pete, jim snow and R A Wrench like this.
  12. oldsman41
    oldsman41
    I don’t like looking at a car and seeing a gas door on the side of the fender it kind of takes away the flow of the lines. With the pop out caps you don’t have to open the trunk and they look good as long as they are same color as the car. Just my opinion
  13. egads
    egads
    1963 Ford Galaxie--[​IMG]
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
  15. Roothawg
    Roothawg
    I've been trying to think of a way to hide one in a pickup. I have pondered having one of the wood planks hinge.
  16. lippy
    lippy
    from Ks
    Are the trunk mounted fillers vented into the trunk? Lippy
  17. Roothawg
    Roothawg
    I wondered that also.
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
    This just popped up by coincidence on a Tri-Five forum. No explanation as to why other than it was built in France???
    Okie Pete, mario711, rbrewer and 2 others like this.
  19. You could do like I did on my 54 and run a hose from the tank up inside the fender ABOVE the filler neck and add a vent. I used one of these from TanksInc and tack welded a brake hose bracket to hold it.
    [​IMG][​IMG]
    Okie Pete, Hamtown Al and juan motime like this.
  20. Roothawg
    Roothawg
    I have one of those in the stake pocket on my bed. It fits perfect and it's out of sight.
    Okie Pete, Hamtown Al and Tman like this.
  21. Mr48chev
    I'd have to say that a lot were/are. I've seen some with a sealed box around them with a lid that seals, One in particular has a steel ammo can around it that you pop the lid on to get to the gas filler. That thing took up a lot of room but had a good drain tube that also worked as a vent for the box. The owner said that he had spilled gas in the trunk when he first had the car on the road and the ammo can was sitting on the shelf in his garage when he started thinking about how to fix the problem.
    Those 56 Chevy flipping tail lights always seem to be too attractive for old fart non car guys at shows. They always seem to want to pop them open to show their buddy how they work on cars that don't belong to them. I saw one get broken at a show that way years ago and the old dude was lucky he survived the fit the owner threw after he broke it and all that ended up happening to him was that he was escorted to the gate and kicked out and told not to come back.
    Okie Pete and Tman like this.
  22. Roothawg
    Roothawg
    They are not cheap either.....
  23. I had no idea where they hid the filler neck on the Tucker 48!
    :rolleyes:
  24. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ Front left quarter. :)
    ClayMart likes this.
  25. Ryan
    Ryan
    ADMINISTRATOR
    It's interesting to me that Detroit worked so hard to hide the fuel filler for over a decade... and then at one point in the 1960's or so, they were just like, "fuck it" and the fuel door became the norm even on Cadillacs...
    Okie Pete, Tim, Sancho and 8 others like this.
  26. DDDenny
    I realize this is probably pushing the genre here but I thought I'd show a seldom done, as in I've never seen another "custom" fuel filler like the one I did on my Suburban.
    Wasn't planned but when I discovered the carnage from an old repair I replaced the quarter panel with the pickup version.
    I put a cable operated tailgate release in there when I shaved the handle, I also filled the license plate cove.
  27. Hey DDDenny, cool set-up. But I gotta ask. Hidden gas filler with a locking gas cap. "Just where the hell are you parking the Burb? "o_O
