12 Volt Overdrive Solenoid Solution
Discussion in 'The Hokey Ass Message Board' started by Crookshanks, Jul 29, 2016.
  1. Crookshanks
    Crookshanks
    So we've got three Chryslers with overdrives behind stock flatheads - two eights and a six. The one we converted to 12 volt seems to be frying solenoids. Anybody know a solid testing method and are there any 12 volt options for these old ODs??
  2. squirrel
    what old OD is it? The M-6?
  3. Crookshanks
    Crookshanks
    Squirrel, It's stock '39 Imperial OD. Gotta get under there and scrape some grime and see.
  4. Cosmo49
    Cosmo49
    What does "...seems to be frying solenoids" mean? I pushed 12V through a 6V solenoid for 12 years, no problems, I will follow to learn but as yet have no recommendations for you.
  5. squirrel
    If it's a Borg Warner, there are 12v solenoids for later ones, but they also had different design solenoids for different cars...I think the early ones usually had longer pins or something.
    Posting a picture of the solenoid you have, would be a good start to finding a solution, since most folks who have messed with BW ods probably have not messed with a 39 imperial.
    Cosmo49 likes this.
  6. Crookshanks
    Crookshanks
    We've pushed 12 volts through it for 20 years and now the solenoid is fried - as in not working and making a connection when tested. I have deduced that 12 volts is the problem as our 6 volt overdrives had given no problem. However, this may or may not be the case.
    Cosmo49 likes this.
  7. Crookshanks
    Crookshanks
    It is an Auto-Lite solenoid like the photo represents.
  8. Cosmo49
    Cosmo49
    What's your on center bolt spacing and solenoid pin length? I have a few from the Chevy world.
  9. Crookshanks
    Crookshanks
    Cosmo, I will measure and let you know this weekend. Thanks a ton.
  10. squirrel
    yup, that would be helpful...the picture you linked above (which I already found on my search for more info) doesn't show the important parts.
