Hot Rods 12 bolt pinion seal
Discussion in 'The Hokey Ass Message Board' started by chubbie, Jan 19, 2020.
  1. chubbie
    chubbie
    My 64 f-85 has a '66Chevelle 12 bolt rear end. the pinion seal marks it's territory as well as keeps the bottom of the car from rusting. Long term goals are to fix a lengthy punch list before spring. So I ordered seals gaskets ect. from parts store only to find he has every thing but the pinion seal. So I checked the wide web and it looks like there is no pinion seal for a 12 bolt Chevelle rear end. Pick up only.. Any help from the HAMB? what do you use?
  2. David Gersic
    David Gersic
    from DeKalb, IL
    You didn’t find a GM 12 bolt pinion seal?
    https://www.strangeengineering.net/product/12-blt-car-pinion-seal.html/
    http://www.jegs.com/i/JEGS/555/612104/10002/-1
    https://www.dennysdriveshaft.com/p8...seal_fits_chevy_12_bolt_car__truck_rear_.html
  3. 41rodderz
    41rodderz
    from Oregon
    Check 12 bolt Tom . I would think Napa etc. should be able to order.
    mgtstumpy likes this.
  4. 41rodderz
    41rodderz
    from Oregon
    I was just going to say go to a bearing place , they should be able to match your seal.
  5. chubbie
    chubbie
    Yes all 3 are listed as pick up too. The car and pick up are different. Looks like no on makes the 12 bolt car seal. What some guys are doing is let the seal set back 1/8"??? some even turn a spacer so the pick up seal can tap in tight. Thanks..
  6. Lloyd's paint & glass
    That's not a truck, it's for a 66 Chevelle. Screenshot_20200119-203900_Samsung Internet.jpg
  7. Mr48chev
    The NATIONAL 8460N should be the correct seal for that rearend. That number will find you one at what ever parts house you go to.
    Lloyd's paint & glass likes this.
  8. Mr48chev
  9. chubbie
    chubbie
    Lloyd I especially like the size BIG print...thanks
  10. chubbie
    chubbie
  11. Lloyd's paint & glass
    You're welcome :D
