Technical 1100 cubic inch projects
Discussion in 'The Hokey Ass Message Board' started by DWBlietz, Dec 6, 2017.
  1. DWBlietz
    DWBlietz
    MODEL GAA-V-8 these engines were built on late 30's-45 they are a all aluminum dohc I guess they were made by ford for the war effort and installed in tanks and other equipment I would like to contact any one that knows any thing about them the books show the front of the engine to have the flywheel what we would like to find out is that we could run it rh or lh rotation any help would appreciated thanks Dennis
    Donuts & Peelouts likes this.
  2. blowby
    blowby
    from Nicasio Ca
  3. Ned Ludd
    Ned Ludd
    Hey Dennis, haven't heard from you in an age!
  4. RichFox
    RichFox
    I had three of those. Still have the manual. Might part with it. Tank two.JPG img93.JPG
  5. sliceddeuce
    sliceddeuce
    Those main bearing caps are...interesting.
  6. RichFox
    RichFox
    The studs went into barrel nuts located in holes in the bearing webs. Two straight down and two at an angle that met centered under the bearing bore. Very well built I thought.
  7. sliceddeuce
    sliceddeuce
    That crankshaft appears to be a multi - part assembly...Ala` Bugatti.
  8. RichFox
    RichFox
    Didn't look multi part to me. And I looked at it pretty close.
  9. sliceddeuce
    sliceddeuce
    aah...I`m seeing the open ends of the hollow rod/main journals.
  10. RichFox
    RichFox
    Yeah. My 56 Packard V8 was the same way. Don't know why Packard thought that was the place to lose weight. The big Ford started out to be an aircraft engine. So weight would be an issue. But by the time it became a tank engine, it seems kind of a waste of effort.
  11. DWBlietz
    DWBlietz
    Thanks for all your replys still haven't figured out that if your srarter turns ccw the engines turns cw if you turn the engine around will it turn ccw or cw or can you turn the engine backwards as apposed to the original rotation thanks for any help Dennis
  12. j-jock
    j-jock
    The reasoning behind using de-rated aircraft engines, was to save weight so they could add more armour. The Brits and the Germans all used the same philosophy. The Brits used the de-rated Merlin engine, and the Germans used a purpose built engine ( for the Tiger and Panther, a Maybach V12, producing 700hp) that was extremely light.
    The early Shermans used the P&W radials, because the Packard-Merlins were needed for the aircraft industry. Later Shermans used the GAA, and it was a sweet sounding engine. We had them for about 6 months in my reserve unit, just before they were retired.
    Bob
  13. You can run any engine backwards/ opposite rotation but You need to correct valve timing and sequence.
  14. i'm curious.....what flywheel/clutch/bell housing /transmission would bolt to that engine? what did they use in a tank?
  15. bundoc bob
    bundoc bob
    WW2 tanks were a concoction of stuff, with the big 3 from Detroit fully involved. The GA
    was 2/3 of a V-12 Henry had developed for similar duty as the Merlin and Allison. There was
    a war on, and time was tight and America had no 500HP engine suitable for tank duty, beyond the
    Continental radial aircraft engine. One of the Green Books Technical Service books has a good
    review of the way Ordnance and Detroit solved the problem in one hell of a hurry. Chrysler threw
    together the 30 cylinder engine based on 5 Chrysler flathead sixes, GM came up with the 2 screaming
    6-71 Jimmies [AKA F'ing Hondas] and Ford took the stillborn V-12 and whacked 4 cylinders off it and
    in the end, for a variety of reasons it became the main Sherman engine. The transmission was a Chrysler
    5 speed as was the hull and a lot of other stuff. Chrysler designed, built and ran the Detroit Tank Arsenal
    and built more tanks there than all of Germany did in 6 years of war.
    banjeaux bob and loudbang like this.
