Hot Rods # 10 Track Roadster Build- Marty Strode
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Jan 24, 2020.
  1. raven
    raven
    When you get a chance, could you expound on your body mounting procedure? I’m just not visualizing it.
    r
  2. Marty Strode
    Marty Strode
    Raven, it will be clear, once the body mounting rails are tacked in place, and the body is removed. I have been getting the rear axle assy ready to install, the housings have been hot-tanked, and blasted. At this time I installed the open drive ring and pinion, had to swap the spider gears from 11 to 12 tooth, to match the 18 tooth 37 axles. IMG_4347.JPG IMG_4348.JPG IMG_4349.JPG
  3. Marty Strode
    Marty Strode
    Today, I got the rear spring stretched, and installed, along with mounting the rear axle. Next will come the modifications to the rear arms. Sorry about all of the clutter in the photos. IMG_4350.JPG IMG_4352.JPG IMG_4354.JPG IMG_4356.JPG IMG_4357.JPG
  4. AmishMike
    AmishMike
    Very interesting “spring stretcher”. More nice work
    Stogy and loudbang like this.
  5. Marty Strode
    Marty Strode
    It comes in handy for quickchanges, with the offset.
    cruiserjohn76, 1947knuck, OFT and 2 others like this.
  6. hotrod1948
    hotrod1948
    from Milton, WI
    What do you use to spread it? A porta power/inerpac?
  7. Marty Strode
    Marty Strode
    It uses 1" all thread, and with a 1-1/2" wrench, turn the nuts to stretch the spring, simple and effective. IMG_4359.JPG IMG_4358.JPG
  8. alanp561
    alanp561
    If Archimedes were around today, I think he'd like to hang out with you;)
  9. Marty Strode
    Marty Strode
    Alan, after your mention of Archimedes, I learned he was born in Sicily, I thought he was from Arkansas.
  10. BadgeZ28
    BadgeZ28
    from Oregon
    Marty, I have no experience putting power to those old rear ends. Do you think it will live with sticky tires and your trans/motor combo?
  11. Marty Strode
    Marty Strode
    The weak link is the axle keys, but with skinny 700 X 16's and being somewhat careful it should survive.
  12. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    If it doesn't, we have ways! :p
  13. Marty Strode
    Marty Strode
    I have (2) VW Bus steering boxes in my stash, a ZF and a Ross. After choosing the Ross, I tore it down for inspection, and found it to be in great condition. The plan is to install the steering and pedals this week. One reason for the slow progress is, I am putting the finishing touches on my '40 Pu chassis, getting the rear stabilizer bar installation complete this weekend.
  14. studebakerjoe
    studebakerjoe
    Marty, are you going to use one of those bus banjo wheels on it?
  15. Weedburner 40
    Weedburner 40
    Marty, ya shoulda called me before you started on your 40.
  16. Marty Strode
    Marty Strode
    I know, I know !
    cruiserjohn76, 1947knuck and loudbang like this.
  17. Marty Strode
    Marty Strode
    It's going to get a 40 Ford wheel and column cup.
  18. RodStRace
    RodStRace
    Mr. Strode, a couple questions, if I may?
    1. I'm sure you got those VW boxes when they were not as valued as they would be today. Is there another alternative that would work and be reasonable if you didn't have these already?
    2. I've seen so many rear stabilizer bars mounted this way (on the axle), but it seems like it would be better to hang it in the chassis and attach to links on each side of the suspension. I realize the unsprung weight savings isn't as great with a complete rear axle, but it just seems like it's 50/50 on mounting but most do it this way. What are your reasons for hanging it on the axle? Easier to control stiffness rather than build it into the Chassis?
  19. Marty Strode
    Marty Strode
    You are correct, in the 90's I could buy those boxes for as little as $50 bucks, then they went up to $150. With the value of early VW Vans, I don't have any idea what a steering box is worth these days, and never thought of an alternative. As far as the stabilizer mounting, GM mounted the bar to the rear axle on their coil spring applications. One thing I wanted, was a clear path for the tailpipes to route between the shock and the frame rail, ending up, outside the fuel tank. My goal was to limit body roll, created by a transverse spring, and make it a pleasure to drive. In all reality, I probably should have gone with parallel springs, as my buddy Dale (Weedburner 40) would have prescribed, the rolled pan would have hid the rear spring hangers. IMG_3569.JPG IMG_4363.JPG
  20. alanp561
    alanp561
    Nah, but his nickname was Arky;)
  21. AmishMike
    AmishMike
    More questions about anti-roll bar. Do your other track roadsters have one? Do you notice big difference in handling with or without? Would decrease unsung weight if mounted to frame which in light car might help handling. Do you bend and make the bar? With what material & thickness? Starting build with coil overs & not planning anti-roll bar. Tks
  22. Marty Strode
    Marty Strode
    Mike, we don't use them on the Track Roadsters, with a wide split on the bones, front and rear, 2014-10-14 124717.jpg you don't encounter any body roll. The pictures I posted are my '40 pu. In this shot, notice the body angle, and the inside tires are pretty light.
  23. What vehicle did that sway bar come out of originally and or what would you recomend for a 2500lb car?
  24. Marty Strode
    Marty Strode
    It's is a universal 13/16" bar that a friend of mine uses on a wide range of vehicles. I had to reshape the ends to fit my application. Back when we had a spring shop with a heat treating oven, I would bend 4140 in the Hossfeld bender, cold. Weld paddles on the ends to connect the links, and have them heat treated. It was great to build to suit the application. Not sure, but my '40 pickup should weigh in the area of 3000 lbs. I have a 1" bar for the front and 13/16 on the rear, or 20 percent smaller on the rear. I am sure there are some experts on here that could probably help you, more than me. BTW, where is Salt Lick ?
  25. Awesome build, great work bud! Also building a track t, great inspiration!
  26. Graham08
    Graham08
    That's some very clean tube work on the sway bar crossmember and back bumper. You certainly know how to make that Hossfeld talk! Mine is one of my favorite tools in the shop.
  27. Marty Strode
    Marty Strode
    Glad to hear that, can't have too many Track Roadsters.
  28. Marty Strode
    Marty Strode
    Tube bending is my favorite aspect of scratch car building. With the cost of dies these days, I have been making inserts to add to die radius selection. Simply bend a 180, and saw the tube down the middle, making an insert to bush the die down to the next smaller size, and use the holding and follow shoe of the smaller size. IMG_4370.JPG IMG_4372.JPG IMG_4373.JPG
  29. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I have used early '50s Ford pickup boxes, made by Gemmer. They are also popular upgrade conversion boxes for Model As. I'm not sure if they are any cheaper than a VW box because they are somewhat in demand, but there are a lotta lot of '50s Ford pickups out there that have been upgraded to IFS and R&P so they're around. Shorten the steering shaft to suit (use a sleeve rosebud welded in for safety).
  30. Stan Back
    Stan Back
    "Marty, I have no experience putting power to those old rear ends. Do you think it will live with sticky tires and your trans/motor combo?"
    Higher than average tire pressure can help, too.
    dwollam, loudbang and kidcampbell71 like this.
