Hot Rods 1-3/4 Dual Pipes big enough (AV8)?
Discussion in 'The Hokey Ass Message Board' started by 55styleliner, Dec 14, 2017.
  1. 55styleliner
    55styleliner
    I am building a 284" stoker 8BA flathead for my AV8. I have 1-3/4 pipes running all the way out the back with a 12" long glass pack muffler on each side. Is that too restrictive for a hot street flathead? IMG_0270.JPG
    Tim and nunattax like this.
  2. Bandit Billy
    Bandit Billy
    Nope. It'll work just fine in my opinion. I have 1 3/4 on a 471 blown 8BA, Smittys, reds headers, sounds stupid cool. Ran fine at speed on the dyno.
  3. pitman
    pitman
    If any concern, you can put a balance tube (an H) config. accross and have less back pressure.
  4. Bandit Billy
    Bandit Billy
    Good point. Here is an interesting observation I made with my car. I originally started the motor and did the burn-in with a crossover. Real estate was locking under the car so we ditched the cross tube and the exhaust tone was soooo much cooler. Like a Harley, flatheads have a signature exhaust noise (even with the blower) that other motors just can't replicate.
    Tim likes this.
  5. Kiwi 4d
    Kiwi 4d
    With 140 cubes per side you will be good. Your average rice burner of 2.3L only has a 1 3/4 pipe. I dont imagine you have a lot of space under there for bigger anyway.
    If you already have 1 3/4 in there run with it .
    Bandit Billy likes this.
  6. missysdad1
    missysdad1
    Not only will 1 3/4" pipes be plenty big, they'll also make the flathead sound "right". Keep both sides separate and you'll get that traditional flaheat "burble" tone that's often lost when larger tubing and "H pipes" are used. A vintage hot rod should also sound vintage...in my humble opinion.
  7. 55styleliner
    55styleliner
    Ok great!! The exhaust came out well and I wasn’t excited about doing it over.
    Tim and Bandit Billy like this.
  8. Bandit Billy
    Bandit Billy
    Sound track? Share, my flatheaded brotha.
  9. UNSHINED 2
    UNSHINED 2
    ^^^^^^^Ditto what he said......^^^^^^^
  10. 55styleliner
    55styleliner
  11. Bandit Billy
    Bandit Billy
    Pipes are too small.
    Just kidding, that sounds awesome!!!!!!
  12. tubman
    tubman
    Dang! That sounds good. And here I spent a lot of time snaking a 2" system back from the 276" Merc on my '36 3-window. I thought I was a hero.:rolleyes:
    55styleliner likes this.
  13. 55styleliner
    55styleliner
    That’s still the tired .030 over 239, that’s why the smoke. I’m pulling the engine next week for the rebuild and cubic inch increase to 284. Supposed to be a Potvin 3/8 cam. Will know for sure once I measure it. May switch to a 1007B for more torque?? Not sure and not easy to switch once back together.
  14. Bandit Billy
    Bandit Billy
    True that! Have fun wit the rebuild, post pictures.
  15. Deuces
    Deuces
    Sounded like a motor cycle from my end....
    Sweeeeeeeeeet! :)
  16. BJR
    BJR
    A flathead engine is too restrictive for a flathead. You will be just fine with 1 3/4" tubes.
  17. dirty old man
    dirty old man
    You've got it right, put blocking plates on the heat riser passages in the intake and it will be great. We always used pennies, but copper pennies are hard to find now.
