Hot Rods 1 1/2 " e-brake cable travel enough?
Discussion in 'The Hokey Ass Message Board' started by supercab78, May 1, 2014.
  1. supercab78
    supercab78
    Will 1 1/2 inch of E-brake cable travel be enough for a 9 inch Ford rear end?
  2. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    It will but it will take a lot of leverage to pull it hard enough. Straight pull e-brake handle wont work. It will have to be pulled with a pedal assembly or lever handle.
  3. supercab78
    supercab78
    I'm using the stock model A lever. I thought I should get an opinion before the final weld up. Hopefully it gives me enough leverage. Thanks!
  4. V8 Bob
    V8 Bob
    I am also using a Model A lever with 10" Bendix brakes, and only need to use the 3rd "notch". You should be fine, just make sure the brakes are properly adjusted. :)
  5. supercab78
    supercab78
    Good to hear, thanks.
