Projects ‘32 tudor project
Discussion in 'Traditional Hot Rods' started by triumph 1, Apr 7, 2018.
  1. triumph 1
    triumph 1
    It turns over smoothly with the pugs out & they’re all dry. I was hoping to clean it thoroughly, re gasket it ,change all the freeze plugs & run it. It was a good running low mileage engine when Ray pulled it last July. I drained decent looking anti freeze from both block drains. My edelbrock intake has the taller ports, so I’ll be good with that. There is a broken exhaust manifold bolt in the head I’ll be addressing today. Unfortunately we all know how lousy engine oil was back then.......
    So if anything looks questionable when I open it up, I’ll be doing a full rebuild.
    Stogy likes this.
  2. triumph 1
    triumph 1
    Well, so far the 324 looks much better inside than the “freshened up” 303 I pulled out & tore down. Hopefully I get the bottom end apart tomorrow.
    brEad, Stogy, kidcampbell71 and 3 others like this.
  3. Yes sir, that is a clean old Olds for sure! don't find them like that very often. How much ridge in the cyl's?
    Stogy likes this.
  4. Hendee
    Hendee
    Cool car for sure. Watching along in your engine swap. Good luck with all.
  5. triumph 1
    triumph 1
  6. triumph 1
    triumph 1
    I haven’t measured it yet. It doesn’t look to bad though.
    Stogy likes this.
  7. triumph 1
    triumph 1
    So, it feels like it’s been forever that I’ve been waiting for Parts.
    I finally have everything I ordered from Ross racing & the machine shop should be finished machining everything next week.
    I’m hoping to get it assembled, installed & broken in b4 winter gets here!
  8. triumph 1
    triumph 1
    Some Parts waiting for their new home.
    It’s been a long time coming.
    gonzo and Stogy like this.
  9. x77matt
    x77matt
    Whoa!!! This Tudor is bad to the bone! Perfect!
    Boden likes this.
  10. Jealous! Wish mine was that nice.:D
  11. triumph 1
    triumph 1
    Thanks! I’m anxious to get it back together.
    Stogy likes this.
  12. 392
    392
    Sweet looking ride. This is a check in thread for sure.
  13. 343w
    343w
    What's going on with the tudor project these days?
  14. triumph 1
    triumph 1
    Just waiting for a warm dry day to do the final wash/clean on the machined block.
    Then I’ll mask, prime, paint & assemble the engine. I’m anxious to get it back together.
    Stogy and chop job like this.
  15. sloppy jalopies
    sloppy jalopies
    The Helgers would blow into the race track at Winterport, ME. with a load of race cars...
    they all went like stink... his boys were having a day one never forgets !
    go Helgers go !
    triumph 1 likes this.
  16. 343w
    343w
    I understand about the northeast winters and priorities etc. I have been collecting parts for my tudor project for 10 years now, had a total knee replacement last Oct. so have had to sideline the build until it gets healed, no kneeling up to now. Keep us posted on your progress Triumph.
  17. triumph 1
    triumph 1
    Finally, life has given me enough free time to do the final cleaning of my block & get some paint on it. IMG_3084.JPG IMG_3088.JPG IMG_3090.JPG IMG_3091.JPG
  18. Alas, lad! Looks good now keep at it:D
    nunattax likes this.
  19. triumph 1
    triumph 1
    Thanks Walt, that’s the plan!
    Stogy likes this.
  20. nunattax
    nunattax
    from IRELAND
    looks good what paint did you use
  21. triumph 1
    triumph 1
    Thanks, I used SEM etching primer. The color is from Fusick & I used SEM clearcoat
    All 3 steps were from spray bombs.
    gonzo, Stogy, 343w and 2 others like this.
  22. triumph 1
    triumph 1
    Made a little progress today................
    I spend more time cleaning parts than I do assembling.[​IMG][​IMG]
    brEad, 32SEDAN, kidcampbell71 and 6 others like this.
  23. Exciting times! What rear seal did you use?
  24. triumph 1
    triumph 1
    Yeah, slow progress is better than no progress I suppose.....
    I used the rubber seal with the shim behind it from best gaskets. I hope it doesn’t leak!
  25. Same that I used and no issues yet.
  26. wheeldog57
    wheeldog57
    Nice to see you back after it bro.
  27. triumph 1
    triumph 1
    Thanks man, it’s tough when life gets in the way sometimes but, I’m determined to get it going.
    kidcampbell71 likes this.
  28. Matlack
    Matlack
    looking good!
  29. 343w
    343w
    Been following you too, glad to see your back. I have a tudor project that started with two frame rails, a body and a 32 truck dash. I have been collecting parts for 10 years and am finally ready to get after it this winter! Thanks to the Hamb classified I have been able to roundup enough parts to build a 60's era high school hot rod..
