Technical ‘32- radius rods hitting the frame
Discussion in 'Traditional Hot Rods' started by PurHell, Nov 18, 2018.
  1. PurHell
    PurHell
    from So Cal
    I picked up a ‘32 that has a semi-traditional “lakes look” roadster with ‘39 underpinning.
    My problem is that the frame has been C-notched and lightly notched/ boxed for the radius arms (closed drive shaft, banjo rear)..but she’s hitting on the radius arms over any small bump..I’d really like to keep my stance as it is if at all possible.
    I can find a lot on C-notching the frame but not much on clearance for the radius rods? I’ve seen a few things were guys start the notching before the rods and sweep up to what would be the C-notch depth and sweep back out to the rear crossmember. It’s been boxed and it looks good..but seems to be a lot of structure to remove even though it’s no deeper than the initial C-notch?
    I guess my other options are, box the notch deeper, more like the C-notch or go inboard with the split ‘35-‘36 bones which opens up another can of worms.
    I’d love any idea of advice you could give...
    I hope I didn’t miss information that’s already been posted.
  2. PurHell
    PurHell
    from So Cal
    08ACEB56-AD7B-4EB1-8A69-EC138D7AC422.jpeg D9A97325-FCD1-48E5-9701-1402722D64FC.jpeg
    kidcampbell71 likes this.
  3. Trad V8
    Trad V8
    from Edinburgh
    PurHell likes this.
  4. PurHell and kidcampbell71 like this.
  5. PurHell
    PurHell
    from So Cal
    Cool.. thanks for the input guys..
  6. rustythumb
    rustythumb
    would '42-'48 front wishbones give enough clearance?
  7. seb fontana
    seb fontana
    from ct
    I believe his clearance issues is with the rear radius rods..
  8. Ralph Moore
    Ralph Moore
    I had this same issue on my build. C notched frame, 37 rear and bones, even shortened bones about 6”.
    I took three leaves out of 40 Ford rear spring during build. First weekend drive noticed the bones hitting on rough spots in road. I put the leaves back and problem went away.
    I know you said you didn’t want to change the stance, but it is the easiest way.
    PurHell likes this.
  9. PurHell
    PurHell
    from So Cal
    Cool.. thanks for the advice
