Art & Inspiration ¡¡¡ The Mother Of All Chopped Threads! ¡¡¡
Discussion in 'The Hokey Ass Message Board' started by JeffreyJames, Dec 6, 2010.
  1. Itchy
    Itchy
    Whats your plans for this one? How much did you take out?
    Lookin good.
  2. Von Richthofen
    Von Richthofen
    I took 4,1/2 out my first chop
  3. scrap metal 48
    scrap metal 48
    5 1/2" chop, louvered panels against doors are for the top.. Going to have roll bar, push bar, moon tank, Pressure pump, single seat, full hood, 3 pedals, lots of gauges, just for something different...........
  4. O
    To each his own, but those are the ugliest tail lights I've ever seen. otherwise bitchin ride.....
  5. lorodz
    lorodz
    id like o see this with a whie or black chopped roadster top
  6. paghosthunters
    paghosthunters
    from PA
  7. smarg
    smarg
    4 inch...
    My Coupe.
  8. hudson hot rod
    hudson hot rod
    My Hudson, already chopped when I got it, not sure how much
  9. LN7 NUT
    LN7 NUT
    My 48 Canadian Dodge (think Plymouth with an identity crisis.) I think it's chopped 3 1/2 inches, but am not certain.
    It was already started when I got it, reasonable engineering, bad welding for some of it, I think a master was using it to teach a newbie... I'm still happy with it and hope to finish it in the summer!
    My dad and I have the door tops on it now, and we fixed a lot of the welds and issues in the chop, still have to do the quarter windows because they are horrendous!
    Does anyone know where I can find dropped 46-48 Plymouth spindles?
  10. LN7 NUT - What's the story with the bus?
  11. LN7 NUT
    LN7 NUT
    It's a large vehicle that carries passengers, the driver gets to wear a hat!
    :D
    The bus is a very long story that can be read here http://www.cardomain.com/ride/2563951 basically it's the only survivour of 44 that were custom built by Western Truck and Auto for Brewster Transport in Banff Alberta for doing ice field tours and other adventures like that! (it went where those big monster truck looking buses go now)
  12. Done back in the day.......hammer weld and lead, six inches.
  13. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I didn't realize they had ergonomic creepers and quartz worklights "back in the day"...
    Dave Mc likes this.
  14. rustryder
    rustryder
    from Dinuba ca
    I chopped a four door now i wont think twice about buying one they are perfect for a very low chop because the extra doors make it easy to get in and out
  15. Baron
    Baron
    Like to see a good side shot of this chop. Looks great in this shot.
  16. rustryder
    rustryder
    from Dinuba ca
    sorry pic dident go through the first time
  17. rustryder
    rustryder
    from Dinuba ca
    another chop merc for the hammerd hambers
  18. dodored
    dodored
    from Concord NC
    Here is the reverse chop on my '32
  19. rodknocker
    rodknocker
    Cut 6" out of every post, cut 2" all the way around the rear windsheild, sld it up, and tucked it under the existing rear roof, cut the package tray and clamped it,welded it back up to keep it centered.[​IMG]
  20. donkeyfarm
    donkeyfarm
    Chopped my coupe 6"
  21. dkWayfarer50
    dkWayfarer50
    from Denmark
    Nice job... Im wondering how you make your window lower to fit? model A´s and similar are easy because the glass is flat, but it`s not flat on 50´s cars. Is it the original you cut down, or????
  22. Dago 88
    Dago 88
  23. Dago 88
    Dago 88
    My '30 Closed cab chopped 2". 10505579_10204384354551562_1511114217971444512_n.jpg
  24. bschwoeble
    bschwoeble
    My old "64" T-Bird was chopped about 3 1/2 inches. Can't really tell unless it was parked beside a stock T-Bird.
  25. texkbc
    texkbc
  26. 41 Studebaker m15 with 4 inch chop
  27. Drewski
    Drewski
    Before
    Top off, 6" removed
    After....
  28. 55willys
    55willys
    I am chopping my 47 International KB 7" total. I cut 4" out of the doors and leaned the front post back to the door top. Pancaked the roof 3", chopped the windshield 2" and leaned it back about 4" at the top. Cut the center of the windshield and dropped it 5/8" then removed 2 1/2" above the windshield to complete the pancake. I will be taking 1 1/2" out of the rear window to match the side windows and installing it at the same height as the side windows.
    When I leaned the windshield back I cut it loose at the cowl and let the corners drop then flowed the cowl and lower edge together. If I did it again I would have taken the 7" out of the back of the cab at the rear radius of the door top instead of just above the belt line. It would have been easier than having to add a 1/2' strip between the top and the rear door post on the vertical. This is my first chop and I figured that doing a slanted post and having an inner cab skin along with the pancake was the way to go. I figure the herder the better.
    When I see 33-34 Fords chopped I like to see the roof stretch to keep that nice line on the front of the door. If the post is leaned back it needs to be done properly, that means that the whole windshield post all the way down needs to be cut from the cowl and leaned back otherwise you end up with a dogleg in the bottom of he post and the corners of the windshield sticking out and not sealing.
    I will post pics of the International chop when I get a new USB cord to download them off my phone.
  29. biltx77
    biltx77
    from Nor Cal
    Mine in the 80's and today. I'll be bringing it back to the shop this fall. Think it's about a 4 to 5 inch chop and a 6 inch channel.
  30. Dave Mc
    Dave Mc
    my IMG_0995.JPG IMG_0988.JPG IMG_0992.JPG 48 Longdoor
