Can the cotton buffing wheels that usually get mounted in bench grinders be installed in something portable? I want to polish a larger item (beer keg) which would be awkward to hold for long periods of time.
Is an Airstream trailer big enough? How to polish your Airstream with a Porter Cable polisher from Harbor Freight and a few accessories from Home Depot. http://www.airstreamguy.com/polishing_info Your tank should be a breeze compared to this.
I held my keg in front of my baldor pedestal grinder, worked great. If I can do you can to i'm only a 150#.
Large buffer, white wool pads, heavy compound (to start) may need to sand (hand/DA) surface 1st. Silica is evil wear a mask, long sleeves.
http://www.youtube.com/watch?v=dba3911h-1M Do the Youtube cruise and the information is put into action for a more complete understanding of what you need and what to expect. And you are welcome.
Ive done a few aluminum saddle tanks from semi's.I just used my air buffer that I would use to cut paint with a wool pad and 3m super duty compound. The sd compound is a bit too harsh for paint but really does a number on aluminum.
The short answer is yes...the same wheels used on pedestal polishers can be used on hand held. I use 8" on a makita sander/polisher. I've polished literally hundreds of tanks and wheels and anything else you can think of thats aluminum! Posted using the Full Custom H.A.M.B. App!
http://www.buschshineproducts.com/d...-held-buffer-extensionsadap-c-5_32_36_59.html You can install on a 7" grinder Dan
Thanks for the ideas. I'm pretty sure my keg is stainless steel, so a little more rubbing to get it nice and shiny.
Empty the keg first. But wait a few hours before holding it up to the buffer. Edit: I just saw you're from Canada. You'll probably only need to wait one hour.
Maybe not for your case, but buffing wheels can be mounted in place of a table saw blade. This would provide a large surface to rest parts.
I doubt that the keg is stainless but if it is you want to use a Sissal buffing pad first with the black compound followed up by a loose buffing pad with white or green compound. EH.
