Projects Beebe Bros, Vinson, & Sixt "Cackle Car"
Discussion in 'The Hokey Ass Message Board' started by THE-SYNDICATE, Dec 10, 2010.
  1. THE-SYNDICATE
    THE-SYNDICATE
    And then we have a wonderful package of goodies from my good man at DONOVAN! The gear drive is all dialed in and ready for final engine assembly. I also got the call from Pop Bradford a day ago letting me know that my heads are all done and ready to pick up! Now if I can just get the Damn crankshaft back....
    ~RM
  2. THE-SYNDICATE
    THE-SYNDICATE
    Little bit more each and everyday! The cowl has been trimmed up and looks bitchin. The steering box is nestled right where it belongs, and I think we have just uncovered more original parts in the land Down Under. This is the hardest project I have ever worked on but definitely the most rewarding. We grind on!!!
    ~RM
  3. THE-SYNDICATE
    THE-SYNDICATE
    No Bondo Needed....
  4. seatex
    seatex
    Going to be AMAZING! But, just one pass.....................please!
  5. Tom S. in Tn.
    Tom S. in Tn.
    Did they just put a jack under the lower hoop in the rear to raise the car? Couldn't get to all the Dzus in the belly pan until the wheels came off.
    Tom S. in Tn.
  6. Tom S. in Tn.
    Tom S. in Tn.
    I should have used this photo for my question. Tom S. in Tn.
  7. THE-SYNDICATE
    THE-SYNDICATE
    Tom,
    Bruce built the body exactly like it was fresh out of Doug Kruse's shop. To say that it's the best dragster body design is not really true. But it's a work of art and is perfect to the original. Taking the cowl off would be easy but getting the rest of it off is tricky! I imagine back when the guys were running this car they would come back to the cave, pop the cowl, and just pull the motor. Not much remains on the chassis that needed access via the body panels. I would bet that the clutch can never came off during a day at the races. If it did the entire motor was out of the car.
    Cheers,
    RM
  8. dreracecar
    dreracecar
    from so-cal
    There are only 6 Dzus tabs welded to the frame for the body and 14 Dzus's overall (not including the 4 seat). I did put a tab on the lower framerail in front of the rear tire just havent punched the hole, some pics show it some dont , just depends on what month the picture was taken.
  9. Tom S. in Tn.
    Tom S. in Tn.
    I was curious how you'll put a jack under it with the belly pan that remains on.
    I'm with the guy above and would give $10 for a ticket right now to see this baby at full throttle through the lights. Tom S. in Tn.
  10. THE-SYNDICATE
    THE-SYNDICATE
    Not sure Tom.
    I was thinking it would be good to add a jack pad somewhere on the back of the car. I did this on my old Shoemaker chassis and it was really nice. No more worrying about scratching up the body or having the thing slip off when you were in the pits.
    Bruce,
    Do you think there's room to add a little stub somewhere down there to jack this thing up?
  11. dreracecar
    dreracecar
    from so-cal
    You can put a stub on the rear lower frame rail underneath the spine uprite to move car around with a floorjack or to be able to take the rear tires off to polish, but in order to get the center body off you will either have to get the front end way up off the ground or use a hoist to lift the back of the car up by the cage.
    Todays work-- making a scribe to mark the housing for cutting and welding on the bearing ends--- housing width 27"
  12. THE-SYNDICATE
    THE-SYNDICATE
    Yep...
  13. THE-SYNDICATE
    THE-SYNDICATE
    So Bitchin....
  14. THE-SYNDICATE
    THE-SYNDICATE
    Motor parts are all home now as well...
  15. AA/FA 0045
    AA/FA 0045
    Great progress, nice work.
  16. THE-SYNDICATE
    THE-SYNDICATE
    Stopped off at the beach in Santa Barbara yesterday for a little photo opp....
    rottenpop likes this.
  17. ScooterCO
    ScooterCO
    from Parker, CO
    Its not just another beach cruzier!
  18. THE-SYNDICATE
    THE-SYNDICATE
    Added the Mag switch and fuel shut off cable yesterday. Also installed the 3rd member to check both driveline alignment as well as the axles assembled into the housing.
  19. THE-SYNDICATE
    THE-SYNDICATE
    Also was able to fit up the chute pack to the car and I'm now ready to finish up the push bar as well as the mount for the chute lines.
  20. kermiegeddon
    kermiegeddon
    from Tomball Tx
    Anything to update? I've been anxious to see how things are coming along.
    Kermit
  21. THE-SYNDICATE
    THE-SYNDICATE
    Assembling the motor right now. I've got a few details remaining before paint and chrome time. Busy busy!
    Drewfus likes this.
  22. THE-SYNDICATE
    THE-SYNDICATE
    Starter has been secured:
  23. THE-SYNDICATE
    THE-SYNDICATE
    Vintage Packard wires have been made up!
    Drewfus likes this.
  24. Awesome to see the progress, love the imperial covers, are you planning to run these? chrome? have been hunting for a set of these for my coupe but notably hard to come by.
    Love the progress,
    Drewfus
  25. THE-SYNDICATE
    THE-SYNDICATE
    Indeed! That how the original car ran so these will be off to the chrome shop shortly....
    Cheers!
    RM
  26. THE-SYNDICATE
    THE-SYNDICATE
    wvenfield likes this.
  27. Retro61
    Retro61
  28. rooman
    rooman
    You are up early today Robert. Or is it really late last night? :)
    Roo
    ps Looking great mate!
