Need some advise on my next build I'm starting 32 5 window no fenders, flathead ,quick change. With spring is better for a Quick change Model A or Model T ?
I believe that he as asking about the rear spring. It really depends how low you want it to sit. I am not familiar with putting a T or A spring in a 32 but in a model A a reversed eye A spring will lower it about an inch and a T spring will lower it about 3 I believe. My car currently has a reversed eye A spring but I am going to put a T spring in it soon Posted using the Full Custom H.A.M.B. App!
My avatar car has a T rear spring sitting on a stock A rear end. The T spring is lower by several inches which is why I chose to use it. I can't see either one interfering with the qc unless you have some body stuff hanging down there.
