Projects Revamp the old 29'er
Discussion in 'Traditional Hot Rods' started by christensen, Mar 13, 2014.
  1. christensen
    christensen
    from sweden
    Hello hello!
    Tought it was time for a late winter/early spring project!
    So a couple days ago I was in the garage, went around the car and thought that the old tillitson X had past its best before date!
    So i took it off and also the old skew manifold and intake. What to do now?
    I found a manifold flange a friend cut out last year, so I bought some tubing and went to my work and fabricated a cone and started to build me a lake style header :)
    After a couple of curses i got the right angel i wanted
    Cut, grind, cut again and more grinding!
    Finaly the first pipe was fitted
    ImageUploadedByH.A.M.B.1394748193.358967.jpg ImageUploadedByH.A.M.B.1394748207.361454.jpg
    Dont worry, i had it boltes to a big i-beam while i welded!
    Suits me pretty good, my first header!
    Dug out an old 97 to give the banger som gas!
    So now i have to fabricate a intake too ;)
    Started with the flange, made of 5mm steel plate and my best friend, mr.Angelgrinde:)
    Got a gasket as template and i also threaded the holes!
    Then the gas in my mig welder ran out... So i started to take alook at my 97, or all three of them
    After a few mins in the ultra sound cleaner:)
    Now it was the tricky part, to get the emulsion tubes out...
    Drilled just a little bit so i could get a tap in.
    Screw in a m4 bolt with washers and a little nut!
    And...... Profit! I got the nasty little guy out:) just five more!
    That was it for now, have to order som mew tubes and other parts.
    On saturday i will start building the new intake:) thrilled to see how it goes:)
    Hej då from sweden:D
  2. draider
    draider
    from Texas
    Looking good so far!
  3. mikeallcars
    mikeallcars
  4. christensen
    christensen
    from sweden
    Started fabricate the new intake today.
    Cut a tube in half and filled it with a 1" wide plate to get the shape of the flange and piecut it to wrap around a tube
    Cut some bends and mockt it up to see how it would turn out:)
    Trying to get it done this week and hope that the parts i ordered for the carbs will show up!
  5. christensen
    christensen
    from sweden
    Got some work done on the intake this week:) also I got my parts to the carb!
    After some welding and grinding
    Almost done on the bends
    Welded a plate at the opening and grinded it down
    All the parts are tackt in place
    Fully welded
    It's almost done, just need to fit the flange and its ready fore some powdercoating! So tomorrow i will finish the intake and start rebuilding the carb!
    Want to get her out of the garage for a spin now! Got some sweet wether here now:)
  6. 4 banger 4 life
    4 banger 4 life
    from ohio
    nice project..... keep up the good work
  7. christensen
    christensen
    from sweden
    thank you :D
  8. christensen
    christensen
    from sweden
    Tgif!
    Straight to the garage after work!
    Todays plan was:
    • fit the flange to the intake
    • rebuild the carb
    • cut out intake gasket
    • mount intake+carb
    But i got quicker then i tought:)
    So I hookt up the fuleline and hit the starter.... Wrrrrooom !!!
    It is alive again:)
    What a sweet sound! Happy as hell
    But its some work left to do, need to make a connection to the original exhaust and a block-off plate!
    Fabricate a throttle-linkage ,chokecable
    And dressup the fuleline!
    ImageUploadedByH.A.M.B.1395431306.453909.jpg ImageUploadedByH.A.M.B.1395431318.443612.jpg ImageUploadedByH.A.M.B.1395431328.856493.jpg
    This calls for a beer! Cheers!
  9. 3340
    3340
    Nice Work! Enjoyed That Thank You
  10. christensen
    christensen
    from sweden
    Happy to hear that:) i am very happy with the results!
  11. Muttley
    Muttley
    That's a neat little Sedan. How does the Banger sound with the open pipe? Any chance of a YouTube video of the exhaust?
  12. christensen
    christensen
    from sweden
    Check if this works:) in the garage it was REALLY loud! Sonds more like an eight
    https://www.facebook.com/photo.php?v=10203166802268156
    Will try to upload it on the tube or similar
  13. waxhead
    waxhead
    from West Oz
    Banger sounds good in that clip. :D
  14. christensen
    christensen
    from sweden
    Got the exhaust connected today:)
    It was tricky to get the angles i wanted but it turned out well!
    That was the only place i could fit it or else it had hitted something
    ImageUploadedByH.A.M.B.1395950061.211926.jpg ImageUploadedByH.A.M.B.1395950072.954230.jpg
    The "downpipe"
    ImageUploadedByH.A.M.B.1395950106.784681.jpg ImageUploadedByH.A.M.B.1395950120.294090.jpg ImageUploadedByH.A.M.B.1395950135.878351.jpg ImageUploadedByH.A.M.B.1395950149.891581.jpg
    Last thing to do is wrap it in heat/exhaust bandage and its done:)
    Then i will tackle the throttlelinkage and fule line!
    Anyone got some ideas on the linkage??
    The gaspedal is pushing a rod forward and the throttle must go forward to! So "ordinary linkage" wont do it cuz it makes the second rod to a drag the throttle backwards!
  15. Nice project. It sounds killer with that megaphone exhaust. Your fuel line filter is a bit scary though. Any leak and everything will go up in flames.
  16. peter schmidt
    peter schmidt
    from maryland
    Make an arm with a pivot in the center and hook the throttle to the bottom and to the carb at the top that way when you push the throttle it will pivot and pull at the carb side that's how my zepher intake is. What all did you do to the carb I'm about to make a header and mount my 97 soon. Here's a pic of the intake with the linkage I was talking about
  17. christensen
    christensen
    from sweden
    Thanks dude:) the sound is even more killer in real! The fule filter is going away for good any moment:)
    Peter, my throttle is pushing forward and also the carb ! So that linkage wont work
  18. peter schmidt
    peter schmidt
    from maryland
    Oh I must have miss read any way you can just flip that linkage on the carb to the top maybe then you would be able to do it? I'm sure you'll figure something out. Car sounds great
  19. christensen
    christensen
    from sweden
    Hello again:)
    Yesterday i got the Throttle linkage done and the "downpipe" wrapped in heatbandage!
    Found a little arm to the carb so i colud have the linkage on the outside!
    Made the linkage arm out of a 5mm plate, the upper linkage arm from "anglelinks" and a rod!
    After some heat, monkeywrench and sledgehammer it turnd out good, just need to insert a bushing in the pivot hole
    ImageUploadedByH.A.M.B.1396551595.379301.jpg ImageUploadedByH.A.M.B.1396551633.685344.jpg ImageUploadedByH.A.M.B.1396551644.183395.jpg
  20. 4 banger 4 life
    4 banger 4 life
    from ohio
    how well does the carb work backwards. ? i have never seen it done b 4.
  21. classic gary
    classic gary
    My thought is, why wouldn't it work backwards
  22. christensen
    christensen
    from sweden
    After a look on the web, it seems that alomst everybody runs whit the bowl forward!
    Maybe i should turn it?
    U guys who is running with strombergs/hollys on a banger, do u need a fulepump and pressuregague?
  23. on hard acceleration it could starve the jets if the fuel level gets low since they are now at the front of the bowl not the rear like if the carb was the other way around
  24. classic gary
    classic gary
    it's an A, hard acceleration?
  25. classic gary
    classic gary
    Not try stealing your thread, but....here's a thought for your next intake manifold. Holley 350 cfm, side hung bowl, small air cleaner, 6 volt electric fuel pump, everything fits under the stock hood. And it ran GREAT.
  26. christensen
    christensen
    from sweden
    Sweet build! looks cool, just bought myself a 6v fule pump :) thinks it would do the trick! i will mount the fule pump under the gastank
  27. SJR
    SJR
    Looks great! just cant close the hood HAAAAA
  28. christensen
    christensen
    from sweden
    Gonna pull out the pins and remove the hoodsides ;)
