Technical 28-29 Model A Garnish?
Discussion in 'The Hokey Ass Message Board' started by ty johnson, Mar 25, 2014.
  1. ty johnson
    ty johnson
    Does anyone have a pic on how the windshield garnish molding sits in place on a 29 Model A coupe or sedan? I didn't have any and bought some repops. I have to chop them but need to know how the sit in place. Do they over lap the edges of the A pilar or sit against them? I'll get a pic real quick.
    Thanks,
    Ty
  2. ty johnson
    ty johnson
    The first pic sits against the post. The second overlaps. How is it suppose to sit is my ?.
  3. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Good question. I have the same question and have to chop mine too.
  4. ty johnson
    ty johnson
    Hopefully somebody can post a pic of how theirs is for us.
  5. ty johnson
    ty johnson
    Guess nobody has a 28-9 Model A that they'd like to share info on.
  6. Grey Kepi
    Grey Kepi
    Will a 1930 be the same. If so I have pics
  7. silversink
    silversink
    I'll go out and get pictures in a min. --- all I have to do is figure out how to post them. PM your email maybe better
  8. Corn Fed
    Corn Fed
    Why are you cutting them in the middle? Simply cut the amount off the top you need, drill a new upper mounting hole, and push in a new countersink for the hole. Done. No welding required.
  9. silversink
    silversink
    pictures didn't come out real good , but mine sits like the second picture---not overlapped. I don't think mine has ever been off the car, but no guarantees.
  10. ty johnson
    ty johnson
    If you cut the tops off the swing arm will be too high. I cut some out of the top and below the pivot bolt.
  11. olskool34
    olskool34
  12. olskool34
    olskool34
  13. ty johnson
    ty johnson
    Yes! Thank you. I was thinking that it rested against the post and not over lapped. But these are repop parts and have to chop and make them fit as you know.
    Thanks.
    Ty
  14. Corn Fed
    Corn Fed
    Not if you simply cut material off the top of the windshield frame when you chop it. Then the distance from the bottom of the windshield to the swing arm pivot stays the same for the body, moldings, and w/s frame. I've done it this way on 2 cars and it works fine.
  15. ty johnson
    ty johnson
    Corn fed your right. I'm being difficult.
  16. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Thanks, Olskool!
  17. olskool34
    olskool34
    No problem man. glad I could help you guys out.
