Just wanted to ask for help in predicting my ride height ...I installed some areo star from coils on my shoebox I know about settling ........ How much lower will she drop after the springs relax ...and settle in ? Right now center of axle to fender lip Front 27" Rear 17" Rear is sitting just right front needs to go 2 " more Will it settle ? Should I cut 1/2 coil ? 1 coil ? Any help is appreciated Posted using the Full Custom H.A.M.B. App!
I'm happy with the drop i got with the springs. Any more your going to loose suspention travel and run out of camber adjustment. Unless your into static display. If you want more space your lower control arms before you hack your springs or dropped spindles.
As Tedley says.. Dropped Uprights will be your next step. The springs should give you approx 2.5" lowering. The Dropped Uprights will also give you approx 2.5"
Sorry my question is not clear After installing areo star springs new sway bar bushings etc and taking car off of jack stands .....how much will she settle in front Posted using the Full Custom H.A.M.B. App!
Not sure but a little i suspect. Her's a pic of my shoe with areostar springs and 3 in blocks in back. Car is fresh last summer. Wheels are 15 with 225x75. 215's will lower it abit. It may come down abit but i don't think to much.
Just curious what's the measurement from ground to fender well in front? I'm running 205 70 r 15 's Posted using the Full Custom H.A.M.B. App!
I've had the Aerostar front coils on since November and have driven about 250 miles so far. I measured with a yard stick last week and I'm sitting at 26 3/4 inches from center top of the wheel well to the ground. Tires are Coker classic radials in 205/75/15 if that helps. When I get on a computer I will come back and post some photos. I also did the rear using 3" lowering leaf springs from shoebox-central and I've got a measurement of 13 3/4 from the center bottom of the rear skirt to the ground. Hope that helps ? I'll post some pics when I get on my comp
if you decide to get that extra 2 inches via dropped uprights,or just want some information on shoe box suspension, give us a call down here at Gambino Kustoms and we can set ya up. 408 479 4812
I would like some info on shoebox fords How much do you think she'll settle Should I call for the answer? I lowered a 79 c 10 one time looked nice When I set her down .... As I drove it it dropped almost 2 inches Kept slapping the lower control arms on the street at every bridge I crossed ...thanks in advance Posted using the Full Custom H.A.M.B. App!
well the coils could settle if cutting, because you were spreading the load over say 9 coils, so if you remove a coil, you lose its static height and now the load spread over less coils, which could sag, theoretically. Now Drop Uprights, lowers it 2 inches, completely statically, that doesnt change anything with springs. it literally replaces the upright your currently running, and moves the spindle into a location on it 2 inches closer to the upper arm then stock. call us
The new Aerostar springs aren't going to settle that much. I've got 3" blocks and Aerostar springs in mine, but it's up on stands these days so I can't take measurements for you.
OK cool Much appreciated I was hoping they would relax a little May go for the uprights Just worried if it settled it may be to low Posted using the Full Custom H.A.M.B. App!
Dropped uprights with the Aerostar coils are a great combo to lower the Shoebox. Thats what I am doing. I got mine from Gambino Kustoms.. Good people !!
My car does not sit as low as Rocky's, so if you want that sort of stance you're going to want the dropped uprights. If you're using new, not junkyard, Aerostar springs you don't need to worry about settling.
Using moog aero star springs Rocky's looks killer but to low for me What do you think about 1 / 2 a coil Off springs ....looking for another inch Just to fill space in wheel well ... On the back 3 inch blocks 51 shackles Posted using the Full Custom H.A.M.B. App!
I had Aerostar springs with 1/2 coil cut off. Definately brought it down almost to where wheel lip was even with top of white walls. They were 14" to. I had the rear lowered with 3" blocks and 2 leaves removed. Front rode nice, rear would bang. I've since 4 linked and air bagged the rear and lowered uprights and stk Aerostar springs on front. All from Gambinos kustom. Top notch guys. This pic is Aerostar springs cut. Posted using the Full Custom H.A.M.B. App!
I have Jamco drop spindles with Aerostar springs and their sway bar up front and in rear Jamco rear 4" springs and 3" blocks in back. I had 4" blocks in the back but when I had a 22 gallons in the mustang tank it would hit the crossmember pretty hard when I went over speed bumps. I did raise the tunnel under the rear seat and also pounded the area where the pumpkin of the rearend is. The front tires do rub the fenders when I am going backwards and turned fully. I can say that if my car wasn't so low I would have had a huge problem when my front shackle bolt sheared off. The trunk floor held it in place somewhat. I do scrape going in a lot of driveways and have to really watch where I'm driving when it comes to bumps and pot holes. I also have the rims and tires off my son's Henry J on it just till I buy new rims and tires in a few weeks. They are 205/65/15s and too small. I use to have 6.70's in front and 7.10 in the back and it road about an inch or so higher. Posted using the Full Custom H.A.M.B. App!
Rolled her outside I'm going to roll like this for a while I think it's not to bad Posted using the Full Custom H.A.M.B. App!
I used Fatman's dropped upright kit and aerostar springs. Jamco dropped rear spring kit with 2" blocks. I don't have the front clip back on, but it already sits low enough that, like Mr. Dickies, I am going to have to watch inclines and speed bumps. I would NOT cut anything off the coils until you had a chance to drive the car for a while. You can always take some off, but you can't weld it back on. Also, you will probably, as mentioned in an earlier post, have to raise your drive shaft tunnel and may have to rework the area over the pumpkin.
Looks great. I have Fatman dropped uprights, aerostars up front. 3" posies lower springs, 2" blocks and 51 shackle holder out back. Steep driveways are a no-no along with speed bumps. 114
I installed Aerostar coils 6 years ago. They have yet to settle. I am running Fatman uprights as well. When I first installed the coils, I was running 6.70-15 tires with a 28.58 height. The fender lip was right at 24.5 inches. I now have g70-15 with a 27.50 height. The fender lip is at 24 inches.
