Black one is 40 to 48 Ford depending on the width. Rust one looks like it would fit a 28 to 35 Ford with the raised nibs inside the studs. But the wheel looks like a 40ish Lincoln with those hubcap clips on there.
this may help or not .the one on the right probably is not 39 chrysler i have two , there should be a hole between the lug holes for aline up stud on brake drum.
