Desoto 276/291 deck height? rods?
Discussion in 'The Hokey Ass Message Board' started by Mnhotrodbuilder, Mar 16, 2014.
  1. Mnhotrodbuilder
    Mnhotrodbuilder
    from Afton, MN
    Do you hemi guru's know what the stock deck height is for a 276/291 Desoto? I have been looking for awhile and have not found the numbers.
    I think the Tex Smith book had it listed but my copy is 6,803 miles away.
    Info I have is for a 330,341 and 345 not the 276/291. 10.375 is the deck height for a tall deck.
    Also, I know BB 6.625 Pontiac rods will work with a some machining. Will the 6.800 BB Pontiac rod work to change to a higher rod to stroke ratio?
    FYI, Custom pistons will be fit to the 291. Also, my crankshaft is de-stroked to 3 inches.
    Thanks
  2. sunbeam
    sunbeam
    Deck 9.54" rod 6.067"
  3. Mnhotrodbuilder
    Mnhotrodbuilder
    from Afton, MN
    Thanks sunbeam I appreciate it! I have the stock rod numbers. I am still trying to figure out if a 6.800 will work with my application.
  4. TR Waters
    TR Waters
    from Vermont
    1. Early Hemi Tech
    You are mixing some information. The Pontiac rod swap is/was being done on the Chrysler 331 and/or 354 engines. The Desoto rod big end width is .930 +/-, where the Chrysler is .990 +/-. The low deck Desoto also has a small 2.061+/- rod journal.
    A sbc rod is better suited for a low deck Desoto.
  5. George
    George
    next obvious question is...why destroke a small cube engine?
  6. sunbeam
    sunbeam
    You should be able to get a piston made with a 1.24 compression height.
  7. Mnhotrodbuilder
    Mnhotrodbuilder
    from Afton, MN
    I got the crankshaft de-stroked already. I assume it was done to stay within a specific racing class back in the day.
    I thought Earlyhemibill ran Pontiacs in his turbo 345? My understanding is Pontiacs were .940 on the big end. I will have to look into this more. SBC rods would be great since there are thousands of options for them. Thanks for the help TR.
  8. George
    George
    What will the CID be?
  9. sunbeam
    sunbeam
    At .030 over on a 291 the bore and stroke would be the same as a 265 Chevy.
  10. TR Waters
    TR Waters
    from Vermont
    1. Early Hemi Tech
    The Pontiac big end width is .995. And even though the math may show a 6.8 rod is possible, it might not be physically possible.
    Another thing not mentioned is if the stock journal diameter was kept with the destroke.
  11. George
    George
    He hasn't said what the stroke is.
  12. TR Waters
    TR Waters
    from Vermont
    1. Early Hemi Tech
    3 inch. It is stated in his opening post.
  13. George
    George
    Ooops!:eek: 265 odd
  14. Mnhotrodbuilder
    Mnhotrodbuilder
    from Afton, MN
    That is a great question on the stock journal size. I will have to check when I get home and let you know.
    George, the block I got with the crank is bored .125 over and sleeved on all 8 with a huge main girdle. I was told it was built to run very high rpm. Maybe they wanted to create a little zinger! I enjoy playing around with the Desoto's. Since speed parts are hard to come by, I'm always looking for interchangeable parts like rods...etc
  15. George
    George
    The 259 Dodge/Plym Polys were popular to convert to hemi for Bonneville because it got them under the 260 cube limit in a Class. Maybe this was for something else.
  16. Mnhotrodbuilder
    Mnhotrodbuilder
    from Afton, MN
    I thought of that also, since with a 3" stroke and a stock bore would give them 260ci. E class at Bonneville if I remember right.
  17. George
    George
    OK, and then someone later went with a max boring.
