Technical Help! Need 1930 chevy steering box rebuilt kit.. Probably Saginaw
Discussion in 'Traditional Hot Rods' started by Tano, Mar 2, 2014.
  1. Tano
    Tano
    from Japan
    I surely removed this from 1930 chevy at Desert Valley Auto Parts in Arizona 10years ago.
    Probably it's Saginaw steering box.
    Though I rubbed a worn gear together, it is not smooth.
    And, there is not no clue for rebuilt gearbox or rebuilt kits.
    It is smaller than Vega and 32 Ford steering box.
    And my Hot Rod cannot put on a big gear box any more.
    Although I have seen this by some 1930s to 1940s Auto repair manual of Motors by chance, it is difficult to find here.
    I don't have Auto repair manual of Motors...
    Help! Does any of you have the info?
      92.6 KB
  2. JohnEvans
    JohnEvans
    from Phoenix AZ
    Buy a lottery ticket as you will have a better chance of a big win than finding any new parts for that box.
  3. Mr48chev
    Bearings are bearing if it has ball or roller bearings your local bearing supply should be able to match the old ones. A bushing may have to be machined for it though.
    The gaskets you could cut from gasket material.
    I can't help on the worm and sector gears if they are too worn to use though. Matching them may be difficult at best.
  4. 33WIRE
    33WIRE
    How about a reversed Corvair box; It would sit right on top of the frame as your stock box does.
  5. Tano
    Tano
    from Japan
    I can get bearings and seals easily here.
    However, I want to find this worm and sector gears.
    When I posted about this on FB, the guy named Frankie said that I have new one.
    I am waiting for info from him.
    And, my friend Dave found the following links.
    http://www.vapinc.com/chevy/Steering Parts/main.html
    If Frankie did not have it, he told me to check here.
    However, I might not be able to pinpoint a worm and sector gears.
    Thanks
  6. Tano
    Tano
    from Japan
    Model A steering box has nearer size and shape.
    However, I want to try that I find rebuilt kit or rebuilt box of this.
    I found the pic of the steering box of 1934 Chevy truck in web.
    Probably this is the same one.
    Thanks
  7. squirrel
  8. Tano
    Tano
    from Japan
  9. Tano
    Tano
    from Japan
  10. Rocky72
    Rocky72
    from Pa.
    I just bought a new sector shaft for my 36 pickup , found it on ebay . Keep looking on there it may take a while but parts for those show up. Good Luck.
  11. Tano
    Tano
    from Japan
    Thanks Rocky,
    I just watch some gears in ebay.
    However, I can't choose my parts.
    Can you pinpoint my worm and sector gears by my manufacturer's name cast?
    http://www.ebay.com/itm/180926153131?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_408wt_648
    http://www.ebay.com/itm/331126044995?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_35wt_886
    http://www.ebay.com/itm/25034911052...AX:IT&_trksid=p3984.m1423.l2649#ht_1472wt_695
    http://www.ebay.com/itm/Shaft-Steer...d=100005&prg=1088&rk=1&rkt=4&sd=250349110526&
  12. squirrel
    Look here for the "identification" numbers, you might or might not be able to find them.
    http://chevy.oldcarmanualproject.com/parts/1929_54/821.htm
    if you look for 262944 you find that it's a 1936 FB
  13. 24riverview
    24riverview
    With those casting numbers it does look like a 1936 1/2-1 1/2 ton steering gear. Is the casting number on the other part of the housing 260367?
    The first 2 ebay links for the pitman shafts are correct for that box. The worm gear shafts are not correct. The original part number for the worm shaft should be 261489.
  14. Rocky72
    Rocky72
    from Pa.
    24riverview is right , the steering box is # 260367 I just checked and thats the number on the one in my 36 1/2 ton.
  15. Tano
    Tano
    from Japan
    Thanks
  16. Tano
    Tano
    from Japan
    Thanks so much
    Though I found aworm gear shafts 261489, it's $ 500....
    http://www.ebay.com/itm/1934-35-36-...ries&hash=item2eca2fbf69&vxp=mtr#ht_595wt_648
    <!-- / message -->
    I do not know which gear I should buy.
    Which from 1 to 4 is right?
    1.
    http://www.ebay.com/itm/180926153131?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_408wt_614
    2.
    http://www.ebay.com/itm/331126044995?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_35wt_852
    3.
    http://www.ebay.com/itm/190826355942?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_292wt_852
    4.
    http://www.ebay.com/itm/310756089713?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_420wt_852
    5.
    http://www.ebay.com/itm/180974840520?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_557wt_614
  17. Tano
    Tano
    from Japan
    Or is there my worm gear here?
  18. 24riverview
    24riverview
  19. 24riverview
    24riverview
    It's not listed so I called them, they do not have that one. I would keep checking ebay, I saw the $500 one which seemed a little high priced. Good luck with your search.
  20. Rocky72
    Rocky72
    from Pa.
    Tano , go over to the www.stovebolt.com and see if you can find anything , maybe someone has the parts you need.
  21. Tano
    Tano
    from Japan
    Thanks so much 24riverview
    It's listed by Buy it Now and free shipping.
    However, I have no choice but to look for others because $500 is too expensive...
  22. Tano
    Tano
    from Japan
    Thank you for advice.
    However, I was not able to look for 261489 because I did not understand how to use the Stovebolt's web enough...
  23. Rocky72
    Rocky72
    from Pa.
    Tano , I went over to the stovebolt and posted to see if anyone over there knows where you can get one , if I hear anything I'll let you know.
  24. 29woodie
    29woodie
    from boston, ma
    You may also check out VCCA site. Someone may have the correct part.
    There are a bunch of great guys over there (though they are not particularly hot rod friendly).
  25. Tano,
    Put a post in the Termites and Bowties thread as well- you might find someone who has an extra!
  26. Tano
    Tano
    from Japan
    Thank you.
  27. Tano
    Tano
    from Japan
    Thanks.
    I'll check VCCA.
  28. Tano
    Tano
    from Japan
    I did not find the Bowties thread web.
    Would you attach the link?
  29. Okie Pete
    Okie Pete
    Is one off a 28 the same ?
  30. Bruce Lancaster
    Bruce Lancaster
    Some stuff to look at if you cannot find good parts...this article, though it is about Model A, has a good section on refitting worn gears and also a section on bad bearing races:
    http://www.abarnyard.com/workshop/steering.htm
    That is something to keep in mind if no good parts appear.
    In this article, it was done because the rebuild parts available for the Model A gears were of poor functional quality...I understand that Bratton's can now supply functional ones.
    Also...how about a Model A box?? Similar in size, and it could even be modified to fit into the Chevy mounting bracket, I think. Cheap, lots of parts available.
    VW bus might be another similar small box.
