What's A Good 4 Banger Motor To Use
Discussion in 'The Hokey Ass Message Board' started by Spork!, May 5, 2010.
  1. xbskt
    xbskt
    I'm surprised noone has mentioned the nasty little mill that lurks under the Subaru WRX hood.
    Making all sorts of HP off the rack in a tiny little package I think it would be worth a look.
    Might need a degree in computers though.
    Jeff
  2. Landseer
    Landseer
    from VA
    3.7 Mercruiser has a vote here.
    For something different, albeit not a banger, but very strong: the 1964 Buick 225CI V6.
  3. gsp392
    gsp392
    I don't have any personal experiance with the Mercruiser, but they sound interesting.
    I know the Ford turbo 140cid (2.3) makes alot of power. If you can find a Mustang SVO, you will have a ton of usable drivetrain parts. Also the Ford Supercharged 262cid (3.8) is a bad ass V6.
  4. Ned Ludd
    Ned Ludd
    It is decomputerizable, though. You can even run a mechanical distributor: a Ford CVH unit is relatively easy to adapt to run off the rear of the right-hand camshaft.
  5. bbc 1957 gasser
    bbc 1957 gasser
    ditto .......
  6. One word - w i d e.
    It's an opposed four, and, as such, simply won't fit.
    Even if you DID fit it in, it looks like crap.
    And, really, a hood scoop on an early car for an intercooler??
    Might as well build a VW...
    Cosmo
  7. nefareous
    nefareous
    from maryland
    I like the old Volvo`s with the twin SU side-draft carbs & 5 speed manual tranny. They also came with a 4 speed auto w/ electric overdrive
  8. V4F
    V4F
    from middle ca.
    i myself like the model 'a' motor . i have an insert motor & its a kick . surprises alot of peeps ................. steve
  9. RichFox
    RichFox
    If your not using an early Banger my next choice would be a rocker arm engine as they look right in a roadster. If not that a DOHC engine for the same reason. Pintos are great but look funny to me. I ran one and went 99mph-14.26 at Fremont in the little blue car to the left. 128 at El Mirage. Still thought it looked funny. GM is selling that DOHC Atlas engine in 4 and 5 cylinder models. The six is fast so I guess the four would be good.
  10. gnichols
    gnichols
    from Tampa, FL
    Or build a oval track inspired car? Perhaps start with parts of an old Midget frame that ran a VW and use the Subaru instead, which is a far better engine from what I hear. Gary
  11. A few years ago , I was looking to buy a vintage midget. One that was on the short list had an Alpha engine in it and the owner said that it had the sound very close to that of an Offy. I never did hear it run but I think if I was going to build another roadster, it would most likely have the Alpha engine. Have you ever heard an Offy powered midget on dirt ?? Ahhhhhh.:)
    Ron
    p.s. I have included a picture of the "B" engine in the current roadster.
  12. gnichols
    gnichols
    from Tampa, FL
    Ron,
    I've only had one Alfa, a new 1300 GT Junior Veloce coupe. I hit 7000 rpm exiting the driveway at the dealer the first time I drove it. 7K is where the red line started! Alfa I-4s have DOHC, cross flow heads with either one or two plugs in the center of the heads, dual side draft carbs or EFI, and split headers. They also have 7 quart finned alum sumps. They sound VERY nice. Gary
  13. Warpspeed
    Warpspeed
    Yup, even the Alpha V6 sounds really nice too, have to agree.
  14. Dawford, do you have any pictures of a Mercruiser 470 all dressed up?
    Sam
  15. Another vote for old school Tempest 4.
    Mickey Thompson's blown 4 in a rail (circa. 1961)
  16. Old Guy
    Old Guy
    This is the Toyota 3TC that I have in my roadster. I got the engine and 5 speed for $250. With a good camshaft and some head work they run pretty strong, especially in a real light car. I think they look like half of a 426 Hemi.
  17. What's wrong with the little Mercruiser 120. I have one now and plan to put it into my present project...Ford "T" Sedan...chopped, vertically sectioned, z'd frame...will fit nice with a Chevy aluminum powerglide and small torque converter. I only have to make up intake and exhaust flanges and may be try a 4bbl or 2 ford 2bbls.:cool: Check the photos
    quote: YOU MUST ALWAYS STRIVE TO BE DIFFERENT IN ORDER TO BE IRREPLACEABLE!
  18. Ned Ludd
    Ned Ludd
    29" from cam cover to cam cover.
    My Morris Minor is 31" from inner wheelwell to inner wheelwell, but it was designed for a flat-four that never made it to production, and on top of that widened 4" at the last moment.
    29" won't interfere with the steering of any of the cars usually hot-rodded. I wouldn't use a Subie in an Austin Seven special, though.
    On a T chassis, the engine would oversail the frame rails by a mere 2" either side. That's barely the cam cover: if you run a hood the heads would poke through. The exhaust ports would discharge well within the space between the frame rails.
    On an A the same applies, only the heads would poke out less and there's more room around the exhaust ports.
    I wouldn't go for a turbocharged Subaru in a hot rod, anyway. NA Suburus can be plenty powerful, and there are always crank-driven superchargers. And carburettor possibilities are endless. I agree that the visuals need work, especially around the plastic cam-belt cover. That taken care of it can be quite a good-looking engine.
    [​IMG] .[​IMG]
  19. encswsm
    encswsm
    Like Dick says This is a neat engine It is an aluminum block so you always have the potential of polishing...
  20. Warpspeed
    Warpspeed
    And they are very light weight for the engine capacity
    And they fit easily into an early banger chassis leaving plenty of room for steering and exhaust.
  21. stainlesssteelrat
    stainlesssteelrat
    from ms
    the little Hurricane F-Head 134 I4 is a good one too.
  22. Has the Ford V-4 fork lift engine been mentioned? Used in many foreign auto's from what I understand.
    Ron
  23. Deuced Up!
    Deuced Up!
    Ford 2.3 is hard to beat. I am building something similar and I found a 2.3L Turbo and 5 speed out of a Thunderbird Super Coupe...That should be quite a bit of motivation for such a project!
    sms1951 likes this.
  24. PackardV8
    PackardV8
    Only 1400-1600cc and a two-bearing balance shaft which always gave problems in the '60s Saabs. Don't take one as a gift.
    The original gutless wonder. Don't take one of those as a gift either. Actually, if offered as a gift, take and sell it to a Jeep restorer. Since they all blew up, cores are difficult to find.
    Key to selecting an engine is to define the engineering, performance, cost and esthetics envelope. How many horsepower do you need? How much can you spend? How important is the period-correct look? How MacGyver are you? Can you fab adapters, clutch linkage, intake and exhaust manifolds?
    jack vines
  25. barrnone50
    barrnone50
    from texas
    You did a great job on the roadster, the motor is very interesting I have been doing some looking at your motor and looks like it would be a good fit for Model a Truck Roadster.It looks like you aren't running the computer on your motor are you? I like doing something different like you did instead of the normal Banger motors.Great Job !! George in Texas
  26. I liked the 2 liter pinto. Much quicker/higher reving than the 2.3. I got screwed so badly on a 2.3 in 1974 mustang, (bought new, by 50,000 miles it was scrap. My fault because I didn't use Motorcraft oil) that I'll never own another Ford product!
    I've heard a lot of good things about the Toyota 4A-GE also. Bro-in-law had an MR-2 that would run pretty hard for a 1.6L motor, later they went to a 2L that also was good.
  27. barrnone50
    barrnone50
    from texas
    :D
    Don't be to hard on ford I got a f150 2003 with 345000 miles with 1 alt tires and battery.:D
  28. elba
    elba
    I would use the drivetrain out of a Pontiac Solstice. It has the ECOTEC engine with lots of power and torque. Smooth idle. My Son has this engine in his HHR SS with the supercharger. Fast and smooth.
  29. tfeverfred
    tfeverfred
  30. Ice man
    Ice man
    I was give a 2001 wrecked Jeep Cherokee, which at first I turned down until I looked under the hood. Had a 2.5 4 banger with a 5 speed. I changed it to a carb and had F/S make a dizzy for it and, wow what a runner. 5 mains and super strong, she liked to scream. The 29 never ran so well.
