Technical 1932 ford chassis + 1940 ford cross steering? can it be done?
Discussion in 'Traditional Hot Rods' started by sawzall, Feb 9, 2014.
  1. sawzall
    sawzall
    assuming you had a deuce chassis, and a complete 40 ford steering box, column and wheel... would this setup work in a deuce frame?
    has anyone done it?
    have any pics..
  2. Do you already have the correct spindles for the cross steering? My memory is that guys got into trouble when they also used a dropped axle. I think with some bending it would work but I have never done it. Have you considered F100 pick up steering?
    Charlie Stephens
  3. tommy
    tommy
    Yes there was a survivor Deuce 5 window that had the whole 39 column from banjo wheel to light switch transplanted at York several years ago. It even had the 39 column drop with locking key and switch. If you convert to hydraulics the classic way with 37 up spindles you will have the needed spindle for cross steering.
  4. 42merc
    42merc
    I bought a '32 cpe several years ago that was built in 1952. They had used all of the '39 components, steering, brakes & engine. The car used the stock axle.
    Although it was crudely built it functioned & steered well.
  5. Randy P
    Randy P
    from Austin, TX
    If I remember correctly, the Ken Gross '32 roadster featured in TRJ had '40 steering. I believe he cut down the sector shaft and resplined it so that it would not stick down so low.
  6. Andy
    Andy
    The Dick Smith roadster at the Ford Museum has 40 cross steering and column shift. Dick did not have room for the shift levers on the pass side so he put them on the drivers side.
  7. sawzall
    sawzall
    so.. deuce frame. 40 box, cross steer, maybe with some mods to the steering arm,
    37 up spindles..
    throw in a spare steering box mount (that I saved from a 40 frame) and I'd have most of the front suspension / steering DONE?
    who said building a deuce was going to be tough??
    oh wait I have no fenders, body or rear... small details..
  8. exStreamliner
    exStreamliner
    Dick Smith also utilized the complete center crossmember... Along with his car, he also did Ermie Immerso and Bob Dyer's roadsters the same way
  9. Pewsplace
    Pewsplace
    Sawzall, it is not the easiest swap but has been done time and time again. I believe Cory on here put one in his roadster. The biggest problem is the length of the steering sector makes the pitman arm too close to the ground. I am not sure how to solve this as Dave Simard did, but it can be done. I will look up the article on how to do it.
    I am starting my Deuce project with front and rear crossmembers, 57 rear end, dropped axle and not much else. Hot rodding is about dreaming, building and having a good time.
    Lynn
    LOU WELLS likes this.
  10. Kiwi 4d
    Kiwi 4d
    We fitted a 47 truck steering box as it had a slightly longer steering column , to enable us to get the box and wheel located correctly. But any cross steer box will work , you may need to lengthen the shaft. It steers like a dream. You can fit these to any 37 to 48 spindles. Just need to have the motor in place to get your clearances right. And get the draglink in the correct plane in relation to the tierod.
  11. tony starr
    tony starr
    some great words here lynn...
  12. Roadsir
    Roadsir
  13. thunderbirdesq
    thunderbirdesq
    Athans roadster...
  14. So-cal Tex
    So-cal Tex
    Send a PM to Cory Taulbert, great guy and very help full, he did it on his deuce roadster and drives the thing everwhere.
    I had planned on using a '40 box as well but found a Vega so I will most likely make that consession.
  15. thunderbirdesq
    thunderbirdesq
  16. 345winder
    345winder
    not really the same, but i used a 46 passanger car stering box & tube on a 33/34 frame with a modified 46 mount. worked great,, other than i had to make some custom headers to clear it worked out great.
  17. gonzo
    gonzo
    Russ Daly's roadster runs a forty Ford box. I considered going this route with my 32 as the cost would be much lower than most of the alternatives and it should yield better performance.
  18. HomemadeHardtop57
    HomemadeHardtop57
    I put one in my old green roadster. Worked fantastic and still does 15,000 miles later. I cut the box mounting plate off a 40 frame and welded it to the inside rail of the chassis. Message Gary T, current owner, if you want the frame rail measurement where it was placed. You just have to be careful of oil pan clearance and steering geometry
  19. Rusty
    Rusty
    Mark Fords's Coupe has one
  20. 343w
    343w
    I am planning to use a 40 steering box with cross steer and 40 spindles. The length of the column is the only question using the original drop and lock switch in my tudor. The body is still not mounted on the frame, so there might be some adjusting involved.
  21. Kevin Lee
    Kevin Lee
    Super Moderator
    Nosurf's A coupe is a shortened AA frame – so similar dimentions as a Deuce frame – with a '48 box and column. I would think some careful mockup time would get you there with few issues.
  22. 57tailgater
    57tailgater
    from Georgia
  23. edwardlloyd
    edwardlloyd
    from Germany
    I've used a 46 box and column in a 32. Even used the mounting bracket cut down a bit. It places the box quite far forward, and makes it tight for headers on the flathead V8. But the column length is great for a channelled pickup. Brings the wheel quite far up so you have room behind it for your legs.
    Twitter @edsrodshop
  24. zibo
    zibo
    from dago ca
    I built a 29 roadster with an A frame/flathead and used a cross steer 37-40 box, a tight fit but it worked even with dropped axle. Was one of the best handling cars. Anyway not the same but it's got to be easier on a 32 frame.
    TP
  25. Did it on my roadster...worked slick and no one else had it!
  26. Cabro32
    Cabro32
    from Pa
    I bought a 32 5W that was built in the 50's about 20 years ago that had that setup. The frame was cracked and bent from fatigued steel. The cross steering puts a twist in the frame every time you turn the steering wheel. The frame from the factory was not designed for cross steering. Box or strengthened the frame rail and should be ok.
  27. Dreddybear
    Dreddybear
    As does my coupe, though it's channeled. Either way, both cars steer GREAT.
    As you can see in this pic, his shaft goes under the headers, the engine sits high.
    My engine sits a little high too. But I still have one piece spindles s,plit bones etc...
    You can sort of see the more extreme tie rod angle here, but it doesn't have any noticeable affect.
    MayDay likes this.
  28. sawzall
    sawzall
    Thanks for the excellent responses... I prefer the engine high in the chassis.. when this happens ita likely that the engine will be a sbc with trips... only time stands in the way!
  29. Von Dago
    Von Dago
    from New Jersey
    Are you building something new?
  30. titus
    titus
    Generally when a person sets up a vega box with cross steering they try and get the box up close so the tie rod and drag links are close to each other, but if you look at any 35-48 ford the box is back further and the drag link is no where near parallel with tie rod. so the first couple pics of cars posted here with the 40 style box has the box mounted way forward, Mark Fords and Dreadybears car is mounted further with more of an angle like Dready stated in his post, the way they did it is the way id do mine.
    JEFF
    MayDay likes this.
