Projects 1956 Ford Pick Up - Need help on a few items
Discussion in 'The Hokey Ass Message Board' started by 1933dodge, Feb 9, 2014.
  1. 1933dodge
    1933dodge
    from MN
    Building a 56 Ford Pick up for daughter in High School?
    1. Is tailgate the same between a f150 and f250 of that Year?
    2. Any difference in long bed vs shortbed on gate?
    3. what aftermarket gas tank works under bed?
    Thanks
  2. hi there ,the 3/4 ton bed is longer wider and taller , sorry the tailgate won't fit ,not sure about gas tanks
  3. willymakeit
    willymakeit
    I'm using a Mustang tank. Some bring the filler out in the bed which I dislike. I ended up using the original filler ad some steel tubing and brought it out in the bed support above the bumper. There's some good info on the Ford Truck Enthusiasts site. A good group of good threads. Hope this helps.
  4. I used a gas tank from a Bronco 2. Not sure of the year, but I know it had an electric fuel pump which I didn't use. fit perfect between the frame rail.
  5. verde742
    verde742
    If you use a Cougar gas tank, same as Mustang , but filler goes out Driver side.
