Projects Model A Haircut
Discussion in 'Traditional Hot Rods' started by JOBCORP, Jan 16, 2014.
  1. JOBCORP
    JOBCORP
    Engines under the bench and around the shop? Too many to even count!
    Made some serious head way, roof is completely welded in, next mouldings cut to size, windshield frame, glass, and finish up doors! Lots of fun when you've got a shop full of characters!
  2. Rehpotsirhcj
    Rehpotsirhcj
    1. Northwest HAMBers
    Nice to hear. I've heard far too much from the other side of the argument lately (unsafe, can't see, etc. etc.).
    OP..great work!
  3. 55willys
    55willys
    Great looking A! When the roof and doors are done you are at the half way mark. That is when I usually get called on to finnish the job:D
  4. milkweed
    milkweed
    from SLC UT
    CAN'T believe You Ruined a stock car......
  5. Muffin
    Muffin
    from Layton, UT
    Game on!
  6. zibo
    zibo
    from dago ca
    Funny I just acquired a 40 year basketcase A coupe,
    and it would be tough for me to start cutting it up,
    although it's the first thing I thought of.
    That's only cause I'm not sure if I can keep it or not!
    Maybe I should stop thinking and just do it!
    TP
  7. JOBCORP
    JOBCORP
    Loudpedal got the windshield frame all lowered to spec! And mounted
  8. Muffin
    Muffin
    from Layton, UT
    Kris finishing up the windshield frame.
  9. Muffin
    Muffin
    from Layton, UT
    Dad started fitting the doors and working on the door hinges. With all the trouble we had getting the pins out he will be installing oversized pins to get the doors working nice.
  10. Muffin
    Muffin
    from Layton, UT
    Woody started building some filler pieces for the tops of the rear windows and the door tops. We decided to try to make pieces rather than splitting the openings to fit the lower half. Woody built a buck to form the pieces he needed.
  11. Muffin
    Muffin
    from Layton, UT
    He then worked the metal around the buck to get the edge he was looking for. Now the pieces just need to be trimmed up and welded in after the door tops go back on.
  12. fatcaddi
    fatcaddi
    Looking killer. When u get bored can I have it?
  13. Sweet we just did the same over the weekend! Hope to post soon.
  14. Deuced Up!
    Deuced Up!
    Man you better cut some holes in that visor so you can see out! LOL LOVE IT!
  15. As always, very nice work guys.
  16. JOBCORP
    JOBCORP
    Mike (elmerfudd) shortened the rear window regulator, wood and all. He also modified the package tray so we could move the seat back, back, back!
  17. Binger
    Binger
    from wyoming
    I like that you kept the rear regulator. Nice looking chop!
  18. JOBCORP
    JOBCORP
    Welding up the tops of the doors
  19. Countn'Carbs
    Countn'Carbs
    from CO
    Dang Hot Rodders....I love it!!!
  20. 340HilbornDuster
    340HilbornDuster
    Awesome Chop!
    Thanks for all the pictures of the good work!
    Good reference when my chop saw comes out later..
    Subscribed!
    T
  21. luke13
    luke13
    theres nothin more traditional than chopin a mint condition one, thats exactly what they did 60 years ago. they wernt chopn beat up old rust buckets back then thats a recent thing.
  22. Young1ne
    Young1ne
    What kind of saw is that that you use. dones't look like a sawmill i have ever seen. When doing a chop like this what is the purpose of the cuts that run up and down. is that to line everything up easier?
    Chop looks killer! More pics of the truck too
  23. Flat-Foot
    Flat-Foot
    from Locust NC
    Great job guys. It looks killer!
  24. ELMER FUDD
    ELMER FUDD
    That is a Milwaukee "Porta-Band", basically a handheld band saw.
    Without those cuts up and down, the quarter windows and the rear window will not line up perfectly because there would be too much material.
  25. JOBCORP
    JOBCORP
    Most cars including model A's are narrower at the top than just above the doors. The "pie" cuts are used to expand or make smaller the panels so they will line up correctly. This must be done on the a pillars especially.
  26. Lowbuckboz
    Lowbuckboz
    Never too nice to cut!! Looks killer!!
  27. A Rodder
    A Rodder
    What did you guys do to line up the A pillars as you look at the car from the front?
    With the three I have done, as you lower the lid down, it is about a half inch wider than the posts coming up from the cowl. I know guys porta power them out but I always thought they would have a kink in them.
    My solution is to cut the ends behind the dash rail and that allows the cowl to flex outwards to match the top without putting an angle on the posts.
    Yours looks good, and I didn't see that you narrowed the header or cut the dash area.
  28. milkweed
    milkweed
    from SLC UT
    The dash rail was split in the middle....
  29. Kool49
    Kool49
    Very nice chop , nice clean work . Thanks for sharing
  30. JOBCORP
    JOBCORP
    We used a port-a-power and unbolted the tank. Then split the dash rail( under the inside dash) I don't have that picture. Then we had the problem of the actual dash. It was now 3/8 too narrow. We debated on moving all the holes but still would have had gaps on both sides. Our solution was to split the dash in two places so all the holes would still line up. See photos! ImageUploadedByH.A.M.B.1392268285.084093.jpg
