Looking for emergency brake ideas- Ford 9"
Discussion in 'The Hokey Ass Message Board' started by Beau, Jan 5, 2014.
  1. Beau
    Beau
    The good old e-brake or parking brake doesn't get talked about much and I'd like to have one. I'm wondering what some of you have done in your Model T/A/B. I'm running a 9" but the idea should still be the same for others. I hooked up a handle and have an idea on how to attach cables, but I'm wondering if there are shorter cables or splitters that work better than others. Any help is appreciated.
    Thanks.
  2. V8 Bob
    V8 Bob
    Lokar cables and kits are really hard to beat, imo. I have them on my '32 and '40, using the stock hand levers. :)
  3. ago
    ago
    from pgh. pa.
    I get my handles out of junk yards and fab the rest. Make sure the two cables pull from a center pivot, like OEM. It distributes the pull evenly on the rear brakes. I don't care for Lokar that pulls from a solid block, The two rear cables don't get equal tension. The OEM is engineered better.
    Ago
  4. I fabricated a combination of the Lokar handle and my homemade block to allow the two cables to be pulled evenly. Works very well. The cables are from the local O'Riellys Auto Parts. ( $33.00 ). I had to shorten them but that's easy enough.
  5. patmanta
    patmanta
    from Woburn, MA
    1. MASSACHUSETTS HAMB
    I got in touch with Bruin Cable a while back. They can make anything you need custom with the specs and measurements. I wasn't far enough along when I last spoke to them so IDK how much it would cost. Their stock cables seem to run around $35.
    http://www.bruinbrakecables.com/
  6. Beau
    Beau
    I like the idea of OEM stuff so I can get it locally. I'm gonna go to the local bearing and cable store and see what sort of stuff they have.
    I had never seen the Lokar kit, thanks for the heads up. That gave me instant ideas.
  7. MT26
    MT26
    1. Virginia HAMB(ers)
    I put a pinion mounted e-brake on my ford 9" rear that's in my 26 T sedan. Works great!
  8. vtx1800
    vtx1800
    I narrowed a 73 Merc Cougar rearend, the cables were toast so I bought two driver side cables because they are the same length, a Parking Brake Cable Repair Kit and the two clips (because i couldn't find the ones I had) and used a Vega parking brake lever. fairly cheap, got it all at Rock Auto. (except the Vega part)
  9. whtbaron
    whtbaron
    from manitoba
    Assume we're all talking rear drum brakes? Saw an aftermarket kit once that put small shoes in the center of disc brakes as well. Never tried them and I forget the brand name, but the idea looked very cool.
  10. ago
    ago
    from pgh. pa.
    Corvette with disc brakes did that also 65-82
  11. tobyflh
    tobyflh
    from Peru il
    Not to get ot but do some people not run an e-brake?
  12. Gman0046
    Gman0046
    V8 Bob X2. Did a Lokar installation on a 32 Ford with a nine inch real easy.
  13. I ran emergency brakes on my 8" in my 32 by measuring what length I needed from each side, then went to Rockauto.com and found the right part numbers. They didn't have them but I managed to order them from NAPA using those part numbers. I then connected it to a floor mounted emergency brake handle from a 36 Chevy truck.
  14. what about Chevy style push down style say from a mid 60's Chevelle? I think it would tuck away nicely on most cars on the left hand side inner cowl? may be ample space if brackets are trimmed up as much as possible, especially if car is an automatic, would be more room without a clutch pedal..I like Ago's idea as well
  15. littlemo
    littlemo
    from Missouri
    this is what I'm trying to "Fab-up" using parts from Lokar, a 1973 Ford Explorer 1/2 ton pickup bracket and the original e-brake handle and cable in my 48 Plymouth sedan. The rearend is an 8.75 from a B-body 66 mopar, with 9" drum brakes. Cass, alias littlemo...
  16. fordor41
    fordor41
    On my '41 Ford I ran 80's, I think, T-bird. About 30" long, from brake backing plate to the frame, both sides. Then fab'd a cable to the stock E-brake cable and back the other side rear. One cable will equalize side to side
  17. adam401
    adam401
    This is a good thread because, true confessions I never include an e brake in builds but it's been bothering me lately. On the t I'm working on I have a 40 ford handle I'll be mounting under the dash to a shortened 40 cable and shield that will pull both cables but it's a10 lbs of crsp in a 5 lb bag.
  18. Cerberus
    Cerberus
    I installed Lokar's twin cable system using a Mustang/Pinto e brake floor mounted lever. Easy, simple, and works well.
  19. McGurk
    McGurk
    from Mid West
    Pinion Disk, mechanical caliper and a single cable.
  20. cheap and effective
  21. One local builder uses a late model GM push on/off pedal for some cars with Lokar cables. Says the pedal assembly is only about $100 from GM. He is also installing non HAMB friendly electric parking brakes in many rides.
    Thinking about the GM set-up for the Wife's 50 Chevy convert.
  22. dirty old man
    dirty old man
    My 31 "A" roadster has 3 pedals and a floor shfter in the floor now, and with my size 14 shoes it's getting damn crowded already in the floor, plus I want to install a fire extinguisher somewhere easy to reach on floor also. I had one in the floor of an OT DD that had an underhood fire, and quick access saved the car.
    Not an awful lot of space to hang a handle from below dash either as I'm 6'3" 250# myself. But I do want an e brake, so I'm seriously considering one of those spring loaded electric jobs they featured in Street Rodder awhile back.
    Some times, you just gotta do what you gotta do!
