LOL!!!!!!!!!! Out goes the tractor motor and in goes the forklift motor Nice build Always impressive to see someone not in the states build an old Ford!!
I don't mean to change the subject, but is your garage ceiling brick? I've never seen that before in a house!
Finaly i lowered the frontaxle with a selfmade Front crossmember... with the reversed spring the frame is 3 "closer to the ground Posted using the Full Custom H.A.M.B. App!
The framework is finaly done.. Next step is to build some mounts for the rear wishbones ... Posted using the Full Custom H.A.M.B. App!
Wishbones are about 4" longer now... the framework is almost done...the pedals and brakesystem are the next steps... Posted using the Full Custom H.A.M.B. App!
I put the body on the frame the first time and cut out the Firewall. Now its time to build the brakes. .stock model a drums with hydro... Posted using the Full Custom H.A.M.B. App!
The maincyl find his final place...i know it is quiet far from the pedals but on this place it will be easy to get on it with the mounted body...it is directly under the seat now. Today i have to finde out why the clutch mechanic is not work right... Posted using the Full Custom H.A.M.B. App!
