literally .5 miles away from my office with storage to boot, couldn't say no. she runs though most likely needs some adjustering. straight 8 in it now is most likely not original as the VIN decoder says this should be a 6 cyl car. im fine with that. if its expedient to get it serviced i will, if not i found a 350 olds rocket with trans that i can drop in. plans are simple on this one. refurb the interior, white or flake the roof, lowering blocks, and cut the front coils. already has a 12v system, new battery, and new brake shoes and lines.
btw yeah, my 53 has the amber "chief" face and lights up with headlight switch. Need a horn button bad!
Yeah, was thinking the same thing. There should be a P for park on it, but maybe the P got covered up in the pic. Anyway it should have N DR4, DR3, Lo, R if it is a hydramatic car. Good condition, you scored! Put a 55 Pontiac 287 in it! (I have one)
